ONTAP FlexCache write-back prerequisites
Before you deploy FlexCache in write-back mode, ensure you have met these performance, software, licensing, and system configuration requirements.
CPU and Memory
It is strongly recommended that each origin cluster node have at least 128GB of RAM and 20 CPUs to absorb the write-back messages initiated by write-back enabled caches. This is the equivalent of an A400 or greater. If the origin cluster serves as the origin to multiple write-back enabled FlexCaches, it will require more CPU and RAM.
Using an undersized origin for your workload can have profound impacts on performance at the write-back-enabled cache or the origin. |
ONTAP version
The origin must be running ONTAP 9.15.1 or later; however, ONTAP 9.15.1 does not have all the necessary fixes and improvements for FlexCache write-back, and is not recommended for production workloads. Significant enhancements for FlexCache write-back were introduced in ONTAP 9.17.1P1. It is strongly advised you run the current recommended release after 9.17.1P1 at both the origin and cache clusters. If you are unable to run ONTAP 9.17.1, the latest P release of 9.16.1 is the next suggested release.
It is strongly recommended that you review the FlexCache write-back guidelines before implementing FlexCache write-back in your environment. -
Any caching cluster that needs to operate in write-back mode must be running ONTAP 9.15.1 or later.
Any caching cluster that does not need to operate in write-back mode can run any generally ONTAP version that supports FlexCache volumes.
Licensing
FlexCache, including the write-back mode of operation, is included with your ONTAP purchase. No extra license is required.
Peering
The origin and cache clusters must be cluster peered
The server virtual machines (SVMs) on the origin and cache cluster must be vserver peered with the FlexCache option.
You do not need to peer a cache cluster to another cache cluster. There is also no need to peer a cache SVM to another cache SVM. |
