ONTAP commands for displaying space usage information
You use the storage aggregate and volume commands to see how space is being used in your local tiers and volumes and their snapshots.
Prior to ONTAP 9.7, System Manager uses the term aggregate to describe a local tier. Regardless of your ONTAP version, the ONTAP CLI uses the term aggregate. To learn more about local tiers, see Disks and local tiers. |
To display information about… |
Use this command… |
Local tier, including details about used and available space percentages, snapshot reserve size, and other space usage information |
How disks and RAID groups are used in an local tier, and RAID status |
The amount of disk space that would be reclaimed if you deleted a specific snapshot |
The amount of space used by a volume |
The amount of space used by a volume in the containing local tier |
