Example: Configure an ONTAP SnapMirror vault-vault cascade
An example will show in concrete terms how you can configure replication relationships one step at a time. You can use the vault-vault cascade deployment configured in the example to retain more than 251 snapshots labeled my-weekly.
The source and destination clusters and SVMs must be peered.
The example assumes the following:
You have configured snapshots on the source cluster with the SnapMirror labels
my-daily,my-weekly, andmy-monthly. -
You have configured destination volumes named
volAon the secondary and tertiary destination clusters. -
You have configured replication job schedules named
my_snapvaulton the secondary and tertiary destination clusters.
The example shows how to create replication relationships based on two custom policies:
The
snapvault_secondarypolicy retains 7 daily, 52 weekly, and 180 monthly snapshots on the secondary destination cluster. -
The
snapvault_tertiary policyretains 250 weekly snapshots on the tertiary destination cluster.
On the secondary destination cluster, create the
snapvault_secondarypolicy:cluster_secondary::> snapmirror policy create -policy snapvault_secondary -type vault -comment "Policy on secondary for vault to vault cascade" -vserver svm_secondary -
On the secondary destination cluster, define the
my-dailyrule for the policy:cluster_secondary::> snapmirror policy add-rule -policy snapvault_secondary -snapmirror-label my-daily -keep 7 -vserver svm_secondary -
my-weeklyrule for the policy:cluster_secondary::> snapmirror policy add-rule -policy snapvault_secondary -snapmirror-label my-weekly -keep 52 -vserver svm_secondary -
my-monthlyrule for the policy:cluster_secondary::> snapmirror policy add-rule -policy snapvault_secondary -snapmirror-label my-monthly -keep 180 -vserver svm_secondary -
On the secondary destination cluster, verify the policy:
cluster_secondary::> snapmirror policy show snapvault_secondary -instanceVserver: svm_secondary SnapMirror Policy Name: snapvault_secondary SnapMirror Policy Type: vault Policy Owner: cluster-admin Tries Limit: 8 Transfer Priority: normal Ignore accesstime Enabled: false Transfer Restartability: always Network Compression Enabled: false Create Snapshot: false Comment: Policy on secondary for vault to vault cascade Total Number of Rules: 3 Total Keep: 239 Rules: SnapMirror Label Keep Preserve Warn Schedule Prefix ---------------- ---- -------- ---- -------- ------ my-daily 7 false 0 - - my-weekly 52 false 0 - - my-monthly 180 false 0 - - -
On the secondary destination cluster, create the relationship with the source cluster:
cluster_secondary::> snapmirror create -source-path svm_primary:volA -destination-path svm_secondary:volA -type XDP -schedule my_snapvault -policy snapvault_secondary -
On the secondary destination cluster, initialize the relationship with the source cluster:
cluster_secondary::> snapmirror initialize -source-path svm_primary:volA -destination-path svm_secondary:volA -
On the tertiary destination cluster, create the
snapvault_tertiarypolicy:cluster_tertiary::> snapmirror policy create -policy snapvault_tertiary -type vault -comment "Policy on tertiary for vault to vault cascade" -vserver svm_tertiary -
On the tertiary destination cluster, define the
my-weeklyrule for the policy:cluster_tertiary::> snapmirror policy add-rule -policy snapvault_tertiary -snapmirror-label my-weekly -keep 250 -vserver svm_tertiary -
On the tertiary destination cluster, verify the policy:
cluster_tertiary::> snapmirror policy show snapvault_tertiary -instanceVserver: svm_tertiary SnapMirror Policy Name: snapvault_tertiary SnapMirror Policy Type: vault Policy Owner: cluster-admin Tries Limit: 8 Transfer Priority: normal Ignore accesstime Enabled: false Transfer Restartability: always Network Compression Enabled: false Create Snapshot: false Comment: Policy on tertiary for vault to vault cascade Total Number of Rules: 1 Total Keep: 250 Rules: SnapMirror Label Keep Preserve Warn Schedule Prefix ---------------- ---- -------- ---- -------- ------ my-weekly 250 false 0 - - -
On the tertiary destination cluster, create the relationship with the secondary cluster:
cluster_tertiary::> snapmirror create -source-path svm_secondary:volA -destination-path svm_tertiary:volA -type XDP -schedule my_snapvault -policy snapvault_tertiary -
On the tertiary destination cluster, initialize the relationship with the secondary cluster:
cluster_tertiary::> snapmirror initialize -source-path svm_secondary:volA -destination-path svm_tertiary:volA
