Determine drive and RAID group information for an ONTAP local tier
Some local tier administration tasks require that you know what types of drives compose the local tier, their size, checksum, and status, whether they are shared with other local tiers, and the size and composition of the RAID groups.
Step
Show the drives for the local tier, by RAID group:
storage aggregate show-status aggr_nameThe drives are displayed for each RAID group in the local tier.
You can see the RAID type of the drive (data, parity, dparity) in the
Positioncolumn. If thePositioncolumn displaysshared, then the drive is shared: if it is an HDD, it is a partitioned disk; if it is an SSD, it is part of a storage pool.
Example: A Flash Pool local tier using an SSD storage pool and data partitions
cluster1::> storage aggregate show-status nodeA_fp_1
Owner Node: cluster1-a
Aggregate: nodeA_fp_1 (online, mixed_raid_type, hybrid) (block checksums)
Plex: /nodeA_fp_1/plex0 (online, normal, active, pool0)
RAID Group /nodeA_fp_1/plex0/rg0 (normal, block checksums, raid_dp)
Usable Physical
Position Disk Pool Type RPM Size Size Status
shared 2.0.1 0 SAS 10000 472.9GB 547.1GB (normal)
shared 2.0.3 0 SAS 10000 472.9GB 547.1GB (normal)
shared 2.0.5 0 SAS 10000 472.9GB 547.1GB (normal)
shared 2.0.7 0 SAS 10000 472.9GB 547.1GB (normal)
shared 2.0.9 0 SAS 10000 472.9GB 547.1GB (normal)
shared 2.0.11 0 SAS 10000 472.9GB 547.1GB (normal)
RAID Group /nodeA_flashpool_1/plex0/rg1
(normal, block checksums, raid4) (Storage Pool: SmallSP)
Usable Physical
shared 2.0.13 0 SSD - 186.2GB 745.2GB (normal)
shared 2.0.12 0 SSD - 186.2GB 745.2GB (normal)
8 entries were displayed.
Related information
