Monitor ONTAP SnapMirror active sync operations
You can monitor the following SnapMirror active sync operations to ensure the health of your SnapMirror active sync configuration:
ONTAP Mediator
Planned failover operations
Automatic unplanned failover operations
SnapMirror active sync availability
Beginning with ONTAP 9.15.1, System Manager displays the status of your SnapMirror active sync relationship from either cluster. You can also monitor the ONTAP Mediator's status from either cluster in System Manager. |
ONTAP Mediator
During normal operations, the ONTAP Mediator state should be connected. If it's in any other state, this might indicate an error condition. You can review the Event Management System (EMS) messages to determine the error and appropriate corrective actions.
You can monitor status and progress of a planned failover operation using the snapmirror failover show command. For example, in a SAN configuration:
ClusterB::> snapmirror failover start -destination-path vs1:/cg/dcg1
Once the failover operation is complete, you can monitor the SnapMirror protection status from the new destination cluster. For example:
ClusterA::> snapmirror show
Refer to the EMS reference to learn about event messages and corrective actions.
During an unplanned automatic failover, you can monitor the status of the operation using the snapmirror failover show command.
ClusterB::> snapmirror failover show -instance
Start Time: 9/23/2020 22:03:29
Source Path: vs1:/cg/scg3
Destination Path: vs3:/cg/dcg3
Failover Status: completed
Error Reason:
End Time: 9/23/2020 22:03:30
Primary Data Cluster: cluster-2
Last Progress Update: -
Failover Type: unplanned
Error Reason codes: -
Refer to the EMS reference to learn about event messages and about corrective actions.
You can check the availability of the SnapMirror active sync relationship using a series of commands, either on the primary cluster, the secondary cluster, or both.
Commands you use include the snapmirror mediator show command on both the primary and secondary cluster to check the connection and quorum status, the snapmirror show command, and the volume show command. For example:
SMBC_A::*> snapmirror mediator show
Mediator Address Peer Cluster Connection Status Quorum Status
10.236.172.86 SMBC_B connected true
SMBC_B::*> snapmirror mediator show
10.236.172.86 SMBC_A connected true
SMBC_B::*> snapmirror show -expand
Progress
Source Destination Mirror Relationship Total Last
Path Type Path State Status Progress Healthy Updated
vs0:/cg/cg1 XDP vs1:/cg/cg1_dp Snapmirrored Insync - true -
vs0:vol1 XDP vs1:vol1_dp Snapmirrored Insync - true -
2 entries were displayed.
SMBC_A::*> volume show -fields is-smbc-master,smbc-consensus,is-smbc-failover-capable -volume vol1
vserver volume is-smbc-master is-smbc-failover-capable smbc-consensus
vs0 vol1 true false Consensus
SMBC_B::*> volume show -fields is-smbc-master,smbc-consensus,is-smbc-failover-capable -volume vol1_dp
vs1 vol1_dp false true No-consensus
