Shut down the controller in an AFF A200 system during the manual boot recovery process
Shut down the controller in your AFF A200 storage system to prevent data loss and maintain system stability during the manual boot media recovery process.
Complete the shutdown of the impaired controller by halting it to the LOADER prompt and capturing the boot environment variables. The LOADER prompt is the safe halted state from which you can replace the boot media.
Take the impaired controller to the LOADER prompt:
If the impaired controller displays… Then… The LOADER prompt
Go to Remove controller module.
Waiting for giveback…Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt (enter system password)
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_nameWhen the impaired controller shows Waiting for giveback…, press Ctrl-C, and then respond
y. -
From the LOADER prompt, enter:
printenvto capture all boot environmental variables. Save the output to your log file.This command may not work if the boot device is corrupted or non-functional.
