Overview of boot media replacement - AFF A250
The boot media stores a primary and secondary set of system (boot image) files that the system uses when it boots.
You must have a USB flash drive, formatted to MBR/FAT32, with the appropriate amount of storage to hold the
image_xxx.tgzfile. -
You also must copy the
image_xxx.tgzfile to the USB flash drive for later use in this procedure.
The nondisruptive and disruptive methods for replacing a boot media both require you to restore the
varfile system:-
For nondisruptive replacement, the HA pair must be connected to a network to restore the
varfile system. -
For disruptive replacement, you do not need a network connection to restore the
varfile system, but the process requires two reboots.
You must replace the failed component with a replacement FRU component you received from your provider.
It is important that you apply the commands in these steps on the correct controller:
The impaired node is the controller on which you are performing maintenance.
The healthy node is the HA partner of the impaired controller.
