Install and maintain
Replace a DIMM in an AFF A250 system
Contributors dougthomp thrisun netapp-jsnyder netapp-martyh netapp-ivanad
Replace a DIMM in your AFF A250 system when the storage system encounters excessive correctable (CECC) or uncorrectable memory errors. Such errors can prevent the storage system from booting ONTAP.
About this task
All other components in the system must be functioning properly; if not, you must contact technical support.
You must replace the failed component with a replacement FRU component you received from your provider.
Step 1: Shut down the impaired controller
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Remove the controller module
You must remove the controller module from the chassis when you replace a component inside the controller module.
Make sure that you label the cables so that you know where they came from.
  1. If you are not already grounded, properly ground yourself.
  2. Unplug the controller module power supplies from the source.
  3. Release the power cable retainers, and then unplug the cables from the power supplies.
  4. Insert your forefinger into the latching mechanism on either side of the controller module, press the lever with your thumb, and gently pull the controller a few inches out of the chassis.
    Note If you have difficulty removing the controller module, place your index fingers through the finger holes from the inside (by crossing your arms).
    Opening the latching mechanism
    Callout number 1
    Lever
    Callout number 2
    Latching mechanism
  5. Using both hands, grasp the controller module sides and gently pull it out of the chassis and set it on a flat, stable surface.
  6. Turn the thumbscrew on the front of the controller module anti-clockwise and open the controller module cover.
    Opening the controller module cover
    Callout number 1
    Thumbscrew
    Callout number 2
    Controller module cover.
  7. Lift out the air duct cover.
    Lifting out the air duct cover
Step 3: Replace a DIMM
To replace a DIMM, you must locate it in the controller module using the DIMM map label on top of the air duct and then replace it following the specific sequence of steps.
Use the following video or the tabulated steps to replace a DIMM:
Animation - Replace a DIMM
  1. Replace the impaired DIMM on your controller module.
    The DIMMs are in slot 3 or 1 on the motherboard. Slot 2 and 4 are left empty. Do not attempt to install DIMMs into these slots.
    Replacing the DIMMs
  2. Note the orientation of the DIMM in the socket so that you can insert the replacement DIMM in the proper orientation.
  3. Slowly push apart the DIMM ejector tabs on either side of the DIMM, and slide the DIMM out of the slot.
  4. Leave DIMM ejector tabs on the connector in the open position.
  5. Remove the replacement DIMM from the antistatic shipping bag, hold the DIMM by the corners, and align it to the slot.
    Note Hold the DIMM by the edges to avoid pressure on the components on the DIMM circuit board.
  6. Insert the replacement DIMM squarely into the slot.
    The DIMMs fit tightly in the socket. If not, reinsert the DIMM to realign it with the socket.
  7. Visually inspect the DIMM to verify that it is evenly aligned and fully inserted into the socket.
Step 4: Install the controller module
After you have replaced the component in the controller module, you must reinstall the controller module into the chassis, and then boot it.
You can use the following illustrations or the written steps to install the replacement controller module in the chassis.
  1. If you have not already done so, install the air duct.
    Installing the air duct
  2. Close the controller module cover and tighten the thumbscrew.
    Closing the controller module cover
    Callout number 1
    Callout number 2
    Thumbscrew
  3. Insert the controller module into the chassis:
    1. Ensure the latching mechanism arms are locked in the fully extended position.
    2. Using both hands, align and gently slide the controller module into the latching mechanism arms until it stops.
    3. Place your index fingers through the finger holes from the inside of the latching mechanism.
    4. Press your thumbs down on the orange tabs on top of the latching mechanism and gently push the controller module over the stop.
    5. Release your thumbs from the top of the latching mechanisms and continue pushing until the latching mechanisms snap into place.
      The controller module should be fully inserted and flush with the edges of the chassis.
  4. Plug the power cords into the power supplies, reinstall the power cable locking collar, and then connect the power supplies to the power source.
    The controller module begins to boot as soon as power is restored. Be prepared to interrupt the boot process.
  5. Recable the system, as needed.
  6. Return the controller to normal operation by giving back its storage: storage failover giveback -ofnode impaired_node_name
  7. If automatic giveback was disabled, reenable it: storage failover modify -node local -auto-giveback true
Step 5: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
