Complete the chassis replacement for an AFF A300 system
Complete the chassis replacement for your AFF A300 system by verifying the HA state of the chassis, switching back aggregates if needed, and returning the failed component to NetApp.
Step 1: Verify and set the HA state of the chassis
You must verify the HA state of the chassis, and, if necessary, update the state to match your system configuration.
In Maintenance mode, from either controller module, display the HA state of the local controller module and chassis:
ha-config showThe HA state should be the same for all components.
If the displayed system state for the chassis does not match your system configuration:
Set the HA state for the chassis:
ha-config modify chassis HA-stateThe value for HA-state can be one of the following:
ha -
mcc -
mcc-2n -
mccip -
non-ha
Confirm that the setting has changed:
ha-config show
If you have not already done so, recable the rest of your system.
The next step depends on your system configuration.
If your system is in… Then… A stand-alone configuration
Exit Maintenance mode:
halt
An HA pair with a second controller module
haltThe LOADER prompt appears. -
Step 2: Switch back aggregates in a two-node MetroCluster configuration
This task only applies to two-node MetroCluster configurations.
Verify that all nodes are in the
enabledstate:metrocluster node showcluster_B::> metrocluster node show DR Configuration DR Group Cluster Node State Mirroring Mode ----- ------- -------------- -------------- --------- -------------------- 1 cluster_A controller_A_1 configured enabled heal roots completed cluster_B controller_B_1 configured enabled waiting for switchback recovery 2 entries were displayed. -
Verify that resynchronization is complete on all SVMs:
metrocluster vserver show -
Verify that any automatic LIF migrations being performed by the healing operations were completed successfully:
metrocluster check lif show -
Perform the switchback by using the
metrocluster switchbackcommand from any node in the surviving cluster. -
Verify that the switchback operation has completed:
metrocluster showThe switchback operation is still running when a cluster is in the
waiting-for-switchbackstate:cluster_B::> metrocluster show Cluster Configuration State Mode -------------------- ------------------- --------- Local: cluster_B configured switchover Remote: cluster_A configured waiting-for-switchback
The switchback operation is complete when the clusters are in the
normalstate.:cluster_B::> metrocluster show Cluster Configuration State Mode -------------------- ------------------- --------- Local: cluster_B configured normal Remote: cluster_A configured normal
If a switchback is taking a long time to finish, you can check on the status of in-progress baselines by using the
metrocluster config-replication resync-status showcommand. -
Reestablish any SnapMirror or SnapVault configurations.
Step 3: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
