AFF A400 chassis replacement workflow
Get started with replacing the chassis of your AFF A400 system by shutting down the controllers, moving the hardware to the replacement chassis, and completing the system restoration.
Shut down the controllers to perform chassis maintenance safely.
Move the fans, drives, and controller modules from the impaired chassis to the replacement chassis.
Complete the replacement by verifying the HA state, switching back aggregates if needed, and returning the failed chassis to NetApp.
