Shut down the AFF A400 controllers to replace the chassis
Shut down the controllers in your AFF A400 storage system to prevent data loss and ensure system stability when replacing the chassis.
Option 1: Shut down the controllers when replacing a chassis
This procedure is for systems with two node configurations. For more information about graceful shutdown when servicing a cluster, see Gracefully shutdown and power up your storage system Resolution Guide - NetApp Knowledge Base.
Make sure you have the necessary permissions and credentials:
Local administrator credentials for ONTAP.
BMC accessibility for each controller.
Make sure you have the necessary tools and equipment for the replacement.
Log into the cluster through SSH or log in from any node in the cluster using a local console cable and a laptop/console.
Stop all clients/host from accessing data on the NetApp system.
Suspend external backup jobs.
If AutoSupport is enabled, suppress case creation and indicate how long you expect the system to be offline:
system node autosupport invoke -node * -type all -message "MAINT=2h Replace chassis" -
Identify the SP/BMC address of all cluster nodes:
system service-processor show -node * -fields address -
Exit the cluster shell:
exit -
Log in to the SP/BMC of each controller using the IP address identified in the previous step:
If you log in from the BMC over SSH, connect using the SP/BMC address (for example,
ssh admin@<SP/BMC_address>), then enter the commandsystem consoleand authenticate. -
If you are using a local console or laptop connected directly to the controller, log in using the same cluster administrator credentials.
Halt the two nodes located in the impaired chassis:
system node halt -node <node1>,<node2> -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover trueFor clusters using SnapMirror synchronous operating in StrictSync mode: system node halt -node <node1>,<node2> -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true -ignore-strict-sync-warnings true -
Enter y for each controller in the cluster when you see:
Warning: Are you sure you want to halt node <node_name>? {y|n}: -
Wait for each controller to halt and display the LOADER prompt.
Option 2: Shut down a controller in a two-node MetroCluster configuration
To shut down the impaired controller, you must determine the status of the controller and, if necessary, switch over the controller so that the healthy controller continues to serve data from the impaired controller storage.
You must leave the power supplies turned on at the end of this procedure to provide power to the healthy controller.
Check the MetroCluster status to determine whether the impaired controller has automatically switched over to the healthy controller:
metrocluster show -
Depending on whether an automatic switchover has occurred, proceed according to the following table:
If the impaired controller… Then… Has automatically switched over
Proceed to the next step.
Has not automatically switched over
Perform a planned switchover operation from the healthy controller:
metrocluster switchoverHas not automatically switched over, you attempted switchover with the
metrocluster switchovercommand, and the switchover was vetoedReview the veto messages and, if possible, resolve the issue and try again. If you are unable to resolve the issue, contact technical support.
Resynchronize the data aggregates by running the
metrocluster heal -phase aggregatescommand from the surviving cluster.controller_A_1::> metrocluster heal -phase aggregates [Job 130] Job succeeded: Heal Aggregates is successful.
If the healing is vetoed, you have the option of reissuing the
metrocluster healcommand with the-override-vetoesparameter. If you use this optional parameter, the system overrides any soft vetoes that prevent the healing operation. -
Verify that the operation has been completed by using the metrocluster operation show command.
controller_A_1::> metrocluster operation show Operation: heal-aggregates State: successful Start Time: 7/25/2016 18:45:55 End Time: 7/25/2016 18:45:56 Errors: - -
Check the state of the aggregates by using the
storage aggregate showcommand.controller_A_1::> storage aggregate show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ ... aggr_b2 227.1GB 227.1GB 0% online 0 mcc1-a2 raid_dp, mirrored, normal...
Heal the root aggregates by using the
metrocluster heal -phase root-aggregatescommand.mcc1A::> metrocluster heal -phase root-aggregates [Job 137] Job succeeded: Heal Root Aggregates is successful
metrocluster healcommand with the -override-vetoes parameter. If you use this optional parameter, the system overrides any soft vetoes that prevent the healing operation. -
Verify that the heal operation is complete by using the
metrocluster operation showcommand on the destination cluster:mcc1A::> metrocluster operation show Operation: heal-root-aggregates State: successful Start Time: 7/29/2016 20:54:41 End Time: 7/29/2016 20:54:42 Errors: - -
On the impaired controller module, disconnect the power supplies.
