Install and maintain
Replace the chassis in an ASA A70 or ASA A90 system
Contributors netapp-jsnyder netapp-lisa dougthomp
Replace the chassis in your ASA A70 and ASA A90 when a hardware failure requires it. Remove the controllers and power supply units (PSUs), remove the drives, install the replacement chassis, and reinstall all components.
Step 1: Remove the PSUs and cables
You need to remove all four power supply units (PSUs), two per controller, before removing the controller. Removing them lightens the overall weight of each controller.
Steps
  1. Remove the four PSUs:
    1. If you are not already grounded, properly ground yourself.
    2. Unplug power cords from the controller module PSU.
      If your system has DC power, disconnect the power block from the PSUs.
    3. Remove the PSU from the controller by rotating the PSU handle up so that you can pull the PSU out, press the PSU locking tab, and then pull PSU out of the controller module.
      Caution The PSU is short. Always use two hands to support it when removing it from the controller module so that it does not suddenly swing free from the controller module and injure you.
      Replace PSU
      Callout number 1
      Terracotta PSU locking tab
    4. Repeat these steps for the remaining PSUs.
  2. Remove the cables:
    1. Unplug the system cables and any SFP and QSFP modules (if needed) from the controller module, but leave them in the cable management device to keep them organized.
      Note Cables should have been labeled at the beginning of this procedure.
    2. Remove the cable management device from the controller modules and set them aside.
Step 2: Remove the controller modules and drives
Remove the controllers from the chassis and then remove the drives from the chassis.
Steps
  1. Check the that amber NVRAM status LED located in slot 4/5 on the back of each controller module is off. Look for the NV icon.
    NVRAM attention and status LED location graphic
    Callout number 1
    NVRAM status LED
    Callout number 2
    NVRAM attention LED
    • If the NVRAM LED is off, go to the next step.
    • If the NVRAM LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact NetApp Support Site for assistance.
  2. Remove the controller modules:
    1. Press down on both of the locking latches on the controller, and then rotate both latches downward at the same time.
      The controller module moves slightly out of the chassis.
      Controller remove graphic
      Callout number 1
      Locking latch
      Callout number 2
      Locking pin
    2. Slide the controller module out of the chassis by the locking latches, and place it on a flat, stable surface.
      Make sure that you support the bottom of the controller module as you slide it out of the chassis.
    3. Repeat these steps for the second controller module.
  3. Remove the drives:
    1. Gently remove the bezel from the front of the system.
    2. Press the release button at the top of the drive carrier face below the LEDs.
    3. Pull the cam handle to its fully open position to unseat the drive from the midplane, and then gently slide the drive out of the chassis.
      The drive should disengage from the chassis, allowing it to slide free of the chassis.
      Note Drives are fragile. Always use two hands to support the drive weight when removing a drive to prevent damage to them.
    4. Keep track of which drive bay each drive was in and set the drive aside on a static-free cart or table.
    5. Repeat this step for the remaining drives in the chassis.
Step 3: Replace the chassis and install components
Remove the impaired chassis, install the replacement chassis, and reinstall all components.
Steps
  1. Remove the impaired chassis:
    1. Remove the screws from the chassis mount points.
    2. Using two people or a lift, slide the impaired chassis off the rack rails in a system cabinet or equipment rack, and then set it aside.
  2. Install the replacement chassis:
    1. Using two people or a lift, install the replacement chassis into the equipment rack or system cabinet by guiding the chassis onto the rack rails in a system cabinet or equipment rack.
    2. Slide the chassis all the way into the equipment rack or system cabinet.
    3. Secure the front of the chassis to the equipment rack or system cabinet, using the screws you removed from the impaired chassis.
  3. Beginning with the bottom controller module, install the controller modules in the replacement chassis:
    1. Align the end of the controller module with the opening in the chassis, and then gently push the controller all the way into the chassis.
    2. Rotate the locking latches upward into the locked position.
    3. If you have not already done so, reinstall the cable management device and recable the controller.
      If you removed the media converters (QSFPs or SFPs), remember to reinstall them.
      Make sure that the cables are connected referencing the cable labels.
  4. Reinstall the drives into their corresponding drive bays in the front of the chassis.
  5. Install all four of the PSUs:
    1. Using both hands, support and align the edges of the PSU with the opening in the controller module.
    2. Gently push the PSU into the controller module until the locking tab clicks into place.
      The power supplies will only properly engage with the internal connector and lock in place one way.
      Note To avoid damaging the internal connector, do not use excessive force when sliding the PSU into the system.
  6. Reconnect the PSU power cables to all four of the PSUs.
    1. Secure the power cable to the PSU using the power cable retainer.
      If you have DC power supplies, reconnect the power block to the power supplies after the controller module is fully seated in the chassis and secure the power cable to the PSU with the thumbscrews.
    The controller modules begin to boot as soon as PSUs are installed and power is restored.
What's next?
After replacing the impaired chassis and reinstalling the components, complete the chassis replacement.
