Install and maintain
Learn about adding and replacing I/O modules in an ASA A70 or ASA A90 system
Contributors netapp-jsnyder dougthomp netapp-lisa
The ASA A70 and ASA A90 systems offer flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding an I/O module is essential when upgrading network capabilities. Replacing an I/O module is essential when addressing a failed module.
You can replace a failed I/O module in your ASA A70 or ASA A90 storage system with the same type of I/O module, or with a different kind of I/O module. You can also add an I/O module into a system with empty slots.
  • Add an I/O module
    Adding additional modules can improve redundancy, helping to ensure that the system remains operational even if one module fails.
  • Hot-swap an I/O module
    You can hot-swap certain I/O modules for an equivalent I/O module to restore the storage system to its optimal operating state. Hot-swapping is done without having to perform a manual takeover.
    To use this procedure, your storage system must be running ONTAP 9.18.1.
  • Replace an I/O module
    Replacing a failing I/O module can restore the system to its optimal operating state.
I/O slot numbering
The I/O slots on ASA A70 and ASA A90 controllers are numbered 1 through 11, as shown in the following illustration.
Slot numbering on ASA A70 and AFF A90 controllers
