Install and maintain
ASA A1K controller replacement workflow
Contributors netapp-jsnyder
Get started with replacing the controller in your ASA A1K storage system by shutting down the impaired controller, removing and replacing the controller, reconfiguring the system settings, and verifying system operations.
To replace the controller module, you must meet certain requirements.
Shut down or take over the impaired controller so that the healthy controller continues to serve data from the impaired controller storage.
Replacing the controller includes removing the impaired controller, moving the FRU components to the replacement controller module, and then installing the replacement controller module in the enclosure.
Verify the low-level system configuration of the replacement controller and reconfigure system settings as necessary.
Transfer the ownership of storage resources back to the replacement controller.
Verify the LIfs, check cluster health, and return the failed part to NetApp.
