Restore and verify the controller configuration in an ASA A1K system
Verify that the controller’s HA configuration is active and functioning correctly in your ASA A1K storage system, and confirm that the system’s adapters list all the paths to the disks.
Step 1: Verify HA config settings
You must verify the HA state of the controller module and, if necessary, update the state to match your system configuration.
Boot to maintenance mode:
boot_ontap maint-
Enter
ywhen you see Continue with boot?.If you see the System ID mismatch warning message, enter
y.
Enter
sysconfig -vand capture the display contents.If you see PERSONALITY MISMATCH contact customer support. -
From the
sysconfig -voutput, compare the adapter card information with the cards and locations in the replacement controller. -
Verify that all components display the same
HAstate:ha-config showThe HA state should be the same for all components.
If the displayed system state of the controller module does not match your system configuration, set the
HAstate for the controller module:ha-config modify controller haThe value for the HA state can be one of the following:
ha -
mcc(not supported) -
mccip(not supported in ASA systems) -
non-ha(not supported)
Confirm that the setting has changed:
ha-config show
Step 2: Verify disk list
Verify that the adapter lists the paths to all disks with the
storage show disk -p.If you see any issues, check cabling and reseat cables.
Exit Maintenance mode:
halt.
After you’ve restored and verified the system configuration for your ASA A1K system, you need to give back the controller.
