Give back the controller in an ASA A1K system
Return control of storage resources to the replacement controller so your ASA A1K system can resume normal operation. The give back procedure varies based on the encryption type used by your system: no encryption or Onboard Key Manager (OKM) encryption.
Return the impaired controller to normal operation by giving back its storage.
From the LOADER prompt, enter
boot_ontap. -
Press <enter> when console messages stop.
If you see the login prompt, go to the next step at the end of this section.
If you see Waiting for giveback, press the <enter> key, log into the partner node, and then go to the next step at the end of this section.
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name -
If automatic giveback was disabled, reenable it:
storage failover modify -node local -auto-giveback true -
If AutoSupport is enabled, restore/unsuppress automatic case creation:
Restore and reseal onboard encryption keys for OKM and return the controller to normal operation.
Before starting, review security key-manager onboard show-backup or contact NetApp Support.
Boot to the ONTAP menu from the LOADER prompt
boot_ontap menuand select option 10. -
Display the key management backup information for the cluster.
Run the following command to display the key management backup information for the cluster:
security key-manager onboard show-backup -
Run the following command to verify the onboard key manager backup:
security key-manager onboard verify-backup
Enter the OKM passphrase and confirm successful verification.
You are prompted twice for the passphrase. -
Enter the backup key data when prompted.
At the boot menu, enter option
1for normal boot. -
Press <enter> when Waiting for giveback is displayed.
Move the console cable to the partner node and login as
admin. -
Give back only the CFO aggregates (the root aggregate):
storage failover giveback -fromnode local -only-cfo-aggregates true-
If you encounter errors, contact NetApp Support.
Wait 5 minutes after the giveback report completes, and check failover status and giveback status:
storage failover showandstorage failover show-giveback. -
Synchronize and verify status of the keys:
Move the console cable back to the replacement controller.
Synchronize missing keys:
security key-manager onboard syncYou are prompted for the cluster-wide passphrase of OKM for the cluster. -
Verify status of the keys:
security key-manager key query -restored falseThe output should show no results when properly synchronized.
If the output shows results (the key IDs of keys that are not present in the system's internal key table), contact NetApp Support.
storage failover modify -node local -auto-giveback trueDo not override veto on giveback for missing keys. Contact NetApp Support. -
After you've transferred the ownership of storage resources back to the replacement controller, you need to complete the controller replacement procedure.
