Install and maintain
Replace an I/O module in an ASA A1K system
Contributors netapp-jsnyder netapp-lisa dougthomp
Replace an I/O module in your ASA A1K system when the module fails. The replacement process involves shutting down the controller, replacing the failed I/O module, rebooting the controller, and returning the failed part to NetApp.
You can use this procedure with all versions of ONTAP supported by your storage system.
Before you begin
  • You must have the replacement part available.
  • Make sure all other components in the storage system are functioning properly; if not, contact technical support.
Step 1: Shut down the impaired node
Shut down or take over the impaired controller.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Replace a failed I/O module
To replace an I/O module, locate it within the enclosure and follow the specific sequence of steps.
Steps
  1. If you are not already grounded, properly ground yourself.
  2. Unplug any cabling on the target I/O module.
  3. Rotate the cable management tray down by pulling the buttons on both sides on the inside of the cable management tray and then rotate the tray down.
    Note This following illustration shows removing a horizontal and vertical I/O module. Typically, you will only remove one I/O module.
    Remove I/O module
    Callout number 1
    I/O cam latch
    Make sure that you label the cables so that you know where they came from.
  4. Remove the target I/O module from the enclosure:
    1. Depress the cam button on the target module.
    2. Rotate the cam latch away from the module as far as it will go.
    3. Remove the module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the enclosure.
      Make sure that you keep track of which slot the I/O module was in.
  5. Set the I/O module aside.
  6. Install the replacement I/O module into the enclosure:
    1. Align the module with the edges of the enclosure slot opening.
    2. Gently slide the module into the slot all the way into the enclosure, and then rotate the cam latch all the way up to lock the module in place.
  7. Cable the I/O module.
  8. Rotate the cable management tray up to the closed position.
Step 3: Reboot the controller
After you replace an I/O module, you must reboot the controller.
Steps
  1. Reboot the controller from the LOADER prompt:
    bye
    Note Rebooting the impaired controller also reinitializes the I/O modules and other components.
  2. Return the impaired controller to normal operation by giving back its storage:
    storage failover giveback -ofnode impaired_node_name
  3. Restore automatic giveback from the console of the healthy controller:
  4. If AutoSupport is enabled, restore automatic case creation:
Step 4: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
