Install and maintain
Review requirements for installing an AFF A20, AFF A30, or AFF A50 storage system
Contributors netapp-lisa netapp-jsnyder
Review the requirements for your AFF A20, AFF A30, or AFF A50 storage system.
Equipment needed for install
To install your storage system, you need the following equipment and tools.
  • Access to a Web browser to configure your storage system
  • Electrostatic discharge (ESD) strap
  • Flashlight
  • Laptop or console with a USB/serial connection
  • Phillips #2 screwdriver
Lifting precautions
Storage systems and shelves are heavy. Exercise caution when lifting and moving these items.
Storage system weight
Take the necessary precautions when moving or lifting your storage system.
The storage system can weigh up to 61.5 lbs (27.9 kg). To lift the storage system, use two people or a hydraulic lift.
AFF A20 A30 A50 and C30 and C60 weight caution icon
Shelf weight
Take the necessary precautions when moving or lifting your shelf.
An NS224 shelf with NSM100B modules can weigh up to 56.8 lbs (25.8 kg). To lift the shelf, use two people or a hydraulic lift. Keep all components in the shelf (both front and rear) to prevent unbalancing the shelf weight.
NS224 with NSM100b lifting caution
What's next?
After you've reviewed the installation requirements and considerations for your storage system, you prepare for installation.
