Complete storage system setup and configuration - AFF A70 and AFF A90
PDF of this doc site
Creating your file...
After you’ve turned on your AFF A70 or AFF A90 storage system, you are ready to discover you cluster network and set up an ONTAP cluster.
Step 1: Gather cluster information
If you have not already done so, gather the information you will need to configure your cluster, such as your cluster management interface port and IP address.
Use the cluster setup worksheet to record the values that you need during the cluster setup process. If a default value is provided, you can use that value or else enter your own.
Step 2: Discover your cluster network
The discovery process enables you to discover your storage system controllers on the network.
If you have network discovery enabled on your laptop, you can complete setup and configuration using automatic cluster discovery.
Connect your laptop to the management switch and access the network computers and devices.
Select an ONTAP icon listed to discover:
Open File Explorer.
Click Network in the left pane and right-click and select refresh.
Double-click either ONTAP icon and accept any certificates displayed on your screen.
XXXXX is the storage system serial number for the target node.
System Manager opens.
If network discovery is not enabled on your laptop, complete the configuration and setup using the ONTAP command line interface (CLI) Cluster Setup wizard.
Make sure your laptop is connected to the serial console port and the controllers are powered on. See power on the storage system for instructions.
Assign an initial node management IP address to one of the nodes.
If the management network has DHCP… | Then… | ||
Configured |
Record the IP address assigned to the new controllers. |
Not configured |
Step 3: Configure your cluster
NetApp recommends that you use System Manager to set up new clusters. See Configure ONTAP on a new cluster with System Manager for setup instructions.
System Manager provides a simple and easy workflow for cluster set up and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols and initial provisioning of attached storage.
After your cluster is initialized, download and run Active IQ Config Advisor to confirm your setup.
