Cable the FAS70 or FAS90 hardware for network and storage connectivity
After you install the rack hardware for your FAS70 or FAS90 storage system, install the network cables for the controllers, and connect the cables between the controllers and storage shelves.
Contact your network administrator for information about connecting the storage system to the switches.
These procedures show common configurations. The specific cabling depends on the components ordered for your storage system. For comprehensive configuration and slot priority details, see NetApp Hardware Universe.
The I/O slots on FAS70 and FAS90 controllers are numbered 1 through 11.
The cabling graphics have arrow icons showing the proper orientation (up or down) of the cable connector pull-tab when inserting a connector into a port.
As you insert the connector, you should feel it click into place; if you do not feel it click, remove it, turn it over and try again.
If cabling to an optical switch, insert the optical transceiver into the controller port before cabling to the switch port.
Step 1: Connect the storage controllers to your network
Cable the controllers to your ONTAP cluster. This procedure differs depending on your storage system model and I/O module configuration.
The cluster interconnect traffic and the HA traffic share the same physical ports. |
Use the Cluster/HA interconnect cable to connect ports e1a to e1a and ports e7a to e7a.
Connect port e1a on Controller A to port e1a on Controller B.
Connect port e7a on Controller A to port e7a on Controller B.
Cluster/HA interconnect cables
Use the 100 GbE cable to connect ports e1a to e1a and ports e7a to e7a.
Connect port e1a on Controller A and port e1a on Controller B to cluster network switch A.
Connect port e7a on Controller A and port e7a on Controller B to cluster network switch B.
100 GbE cable
Step 2: Cable the host network connections
Connect the Ethernet module ports to your host network.
The following are some typical host network cabling examples. See NetApp Hardware Universe for your specific system configuration.
Connect ports e9a and e9b to your Ethernet data network switch.
Do not use ports e1b and e7b for host network connections. Use a separate host card. 100 GbE cable
Connect your 10/25 GbE host network switches.
4-ports, 10/25 GbE Host
Step 3: Cable the management network connections
Use the 1000BASE-T RJ-45 cables to connect the management (wrench) ports on each controller to the management network switches.
Do not plug in the power cords yet. |
Step 4: Cable the shelf connections
The following cabling procedures show how to connect your controllers to a storage shelf. Choose one of the following cabling options that matches your setup.
For the maximum number of shelves supported for your storage system and for all of your cabling options, see NetApp Hardware Universe.
For additional SAS shelf cabling guidance, see SAS cabling rules and concepts - shelves with IOM12/IOM12B modules.
The FAS70 and FAS90 storage systems support DS212C, DS224C, DS460C, and NS224 shelves with either the NSM100 or NSM100B module.
The major differences between the NS224 modules are:
NSM100 shelf modules use built-in ports e0a and e0b.
NSM100B shelf modules use ports e1a and e1b in slot 1.
The following NS224 cabling example shows NSM100 modules in the NS224 shelves when referring to shelf module ports.
Connect each controller to the NSM modules on the NS224 shelf. The graphics show controller A cabling in blue and controller B cabling in yellow.
100 GbE QSFP28 copper cables
On controller A, connect the following ports:
Connect port e11a to NSM A port e0a.
Connect port e11b to NSM B port e0b.
On controller B, connect the following ports:
Connect port e11a to NSM B port e0a.
Connect port e11b to NSM A port e0b.
Cable each controller to the NSM modules on both NS224 shelves. The graphics show controller A cabling in blue and controller B cabling in yellow.
Connect port e11a to shelf 1 NSM A port e0a.
Connect port e10b to shelf 1 NSM B port e0b.
Connect port e10a to shelf 2 NSM A port e0a.
Connect port e11b to shelf 2 NSM B port e0b.
Connect port e11a to shelf 1 NSM B port e0a.
Connect port e10b to shelf 1 NSM A port e0b.
Connect port e10a to shelf 2 NSM B port e0a.
Connect port e11b to shelf 2 NSM A port e0b.
Cable each controller to the IOM modules on both DS460C shelves. The graphics show controller A cabling in blue and controller B cabling in yellow.
mini-SAS HD cable
On controller A, cable the following connections:
Connect port e10a to shelf 1 IOM A port 1.
Connect port e10c to shelf 2 IOM A port 1
Connect port e11b to shelf 1 IOM B port 3.
Connect port e11d to shelf 2 IOM B port 3.
On controller B, cable the following connections:
Connect port e10a to shelf 1 IOM B port 1.
Connect port e10c to shelf 2 IOM B port 1.
Connect port e11b to shelf 1 IOM A port 3.
Connect port e11d to shelf 2 IOM A port 3.
After you’ve cabled the hardware for your FAS70 or FAS90 system, you power on the FAS70 or FAS90 storage system.
