Install and maintain
ASA A20, ASA A30, and ASA A50 chassis replacement workflow
Contributors netapp-jsnyder netapp-lisa
Get started with replacing the chassis of your ASA A20, ASA A30, or ASA A50 storage system by reviewing the replacement requirements, shutting down the controllers, replacing the chassis, and verifying system operations.
Review the requirements to replace the chassis.
Shut down the controllers so you can perform maintenance on the chassis.
Replace the chassis by moving the drives and any drive blanks, controllers (with the power supplies), and bezel from the impaired chassis to the new chassis, and swapping out the impaired chassis with the new chassis of the same model as the impaired chassis.
Verify the HA state of the chassis and return the failed part to NetApp.
