Replace a fan module in a FAS70 or FAS90 system
Replace a fan module in your FAS70 or FAS90 system when a fan fails or is not operating efficiently, as this can affect system cooling and overall performance. Fan modules in FAS70 and FAS90 systems are hot-swappable. The replacement process involves identifying the failed fan module, removing it, installing the replacement fan module, and returning the failed part to NetApp.
Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches. |
Remove the bezel (if necessary) with two hands, by grasping the openings on each side of the bezel, and then pulling it toward you until the bezel releases from the ball studs on the chassis frame.
Identify the fan module that you must replace by checking the console error messages and looking at the Attention LED on each fan module.
Facing the controller module, fan modules are numbered 1 through 5, from left to right.
There is a single LED for each fan. It is green when the fan is functioning correctly and amber when not. -
Press the black button on the fan module and pull the fan module straight out of the chassis, making sure that you support it with your free hand.
The fan modules are short. Always support the bottom of the fan module with your free hand so that it does not suddenly drop free from the chassis and injure you.
Black release button
Set the fan module aside.
Align the edges of the replacement fan module with the opening in the chassis, and then slide it into the chassis until it snaps into place.
When inserted into a live system, the amber Attention LED turns off once the fan is recognized by that system.
Align the bezel with the ball studs, and then gently push the bezel onto the ball studs.
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
