Install an AFF A150 system using video instructions
Install and cable your AFF A150 storage system by following the step-by-step video instructions.
Animation - Install and setup of an AFF A150
If you have a MetroCluster configuration, use the MetroCluster documentation.
Warning: If your system is being installed with ONTAP 9.13.1P8 - 9.13.1P11, ONTAP 9.14.1P1 - 9.14.1P7 or ONTAP 9.15.1 - 9.15.1P2 and your system contains 10 or more internal solid-state drives, you must take additional steps to prepare the system for installation. See issue CONTAP-285173 - ADP does not leave a spare root partition on an AFF A150 with 10 or more internal drives.
