Learn about adding and replacing I/O modules in an AFF A20, AFF A30, or AFF A50 system
The AFF A20, AFF A30, and AFF A50 storage systems offer flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding an I/O module is essential when upgrading network capabilities. Hot-swapping or replacing an I/O module is essential when addressing a failed module.
You can add I/O modules to improve redundancy, helping to ensure that the storage system remains operational even if one I/O module fails. You can add I/O modules when there are slots available or when all slots are fully populated.
You can hot-swap certain I/O modules for an equivalent I/O module to restore the storage system to its optimal operating state. You don't need to perform a manual takeover to hot-swap the module.
To use this procedure, your storage system must be running ONTAP 9.17.1 or later and meet specific requirements for the version of ONTAP your system is running.
You can replace a failed I/O module to restore the storage system to its optimal operating state. This procedure requires a manual takeover of the controller with the failed I/O module.
