Remove the ONTAP hardware system cabinet door
You must remove the system cabinet door and side panels to move the illuminated badge and components, and to reverse the door.
Open the system cabinet door if it is not already open.
Perform the appropriate action depending on whether your cabinets are connected with the interconnect kit.
If your system cabinet is… Then… Not connected to another system cabinet
Go to the next step.
Connected to another system cabinet with an interconnect kit
Remove all four interconnect kit brackets and set the brackets and screws in a safe place.
Unlock both side panels, disconnect the grounding wires from the side panels, and then remove them and set them aside.
Disconnect the grounding wire from the grounding spade located at the top of the door.
Unscrew the grounding lug and wire assembly from the system cabinet frame and set it aside.
Unscrew the grounding lug assembly from the system cabinet door and set it aside.
Lift the top hinge pin until it clears the bottom of the hinge.
Gently tip the top of the door away from the system cabinet frame, and then release the hinge pin.
Lift the door off the bottom hinge, and set the door aside.
