Boot the recovery image on an ASA A70 or ASA A90 system using the automated boot recovery process
After installing the new boot media device in your ASA A70 or ASA A90 system, you can start the automated boot media recovery process to restore the configuration from the partner node.
During the recovery process, the system checks whether encryption is enabled and determines the type of key encryption in use. If key encryption is enabled, the system guides you through the appropriate steps to restore it.
Determine your key manager type:
Onboard Key Manager (OKM): Requires cluster-wide passphrase and backup data
External Key Manager (EKM): Requires the following files from the partner node:
/cfcard/kmip/servers.cfg -
/cfcard/kmip/certs/client.crt -
/cfcard/kmip/certs/client.key -
/cfcard/kmip/certs/CA.pem
From the LOADER prompt, start the boot media recovery process:
boot_recovery -partnerThe screen displays the following message:
Starting boot media recovery (BMR) process. Press Ctrl-C to abort… -
Monitor the boot media install recovery process.
The process completes and displays the
Installation completemessage. -
The system checks for encryption and displays one of the following messages:
If you see this message… Do this… key manager is not configured. Exiting.Encryption is not installed on the system.
Wait for the login prompt to display.
Log into the node and give back the storage:
storage failover giveback -ofnode impaired_node_name -
Go to re-enabling automatic giveback if it was disabled.
key manager is configured.Encryption is installed. Go to restoring the key manager.
If the system cannot identify the key manager configuration, it displays an error message and prompts you to confirm whether key manager is configured and which type (onboard or external). Answer the prompts to proceed. -
Restore the key manager using the appropriate procedure for your configuration:
Onboard Key Manager (OKM)The system displays the following message and begins running BootMenu Option 10:
key manager is configured. Entering Bootmenu Option 10... This option must be used only in disaster recovery procedures. Are you sure? (y or n):
Enter
yat the prompt to confirm you want to start the OKM recovery process. -
Enter the passphrase for onboard key management when prompted.
Enter the passphrase again when prompted to confirm.
Enter the backup data for onboard key manager when prompted.
Show example of passphrase and backup data prompts
Enter the passphrase for onboard key management: -----BEGIN PASSPHRASE----- <passphrase_value> -----END PASSPHRASE----- Enter the passphrase again to confirm: -----BEGIN PASSPHRASE----- <passphrase_value> -----END PASSPHRASE----- Enter the backup data: -----BEGIN BACKUP----- <passphrase_value> -----END BACKUP-----
Monitor the recovery process as it restores the appropriate files from the partner node.
When the recovery process is complete, the node reboots. The following messages indicate a successful recovery:
Trying to recover keymanager secrets.... Setting recovery material for the onboard key manager Recovery secrets set successfully Trying to delete any existing km_onboard.keydb file. Successfully recovered keymanager secrets.
After the node reboots, verify that the system is back online and operational.
Return the impaired controller to normal operation by giving back its storage:
After the partner node is fully up and serving data, synchronize the OKM keys across the cluster:
security key-manager onboard syncGo to re-enabling automatic giveback if it was disabled.
External Key Manager (EKM)The system displays the following message and begins running BootMenu Option 11:
key manager is configured. Entering Bootmenu Option 11...
Enter the EKM configuration settings when prompted:
Enter the client certificate contents from the
/cfcard/kmip/certs/client.crtfile:Show example of client certificate contents
-----BEGIN CERTIFICATE----- <certificate_value> -----END CERTIFICATE-----
Enter the client key file contents from the
/cfcard/kmip/certs/client.keyfile:Show example of client key file contents
-----BEGIN RSA PRIVATE KEY----- <key_value> -----END RSA PRIVATE KEY-----
Enter the KMIP server CA(s) file contents from the
/cfcard/kmip/certs/CA.pemfile:Show example of KMIP server file contents
-----BEGIN CERTIFICATE----- <KMIP_certificate_CA_value> -----END CERTIFICATE-----
Enter the server configuration file contents from the
/cfcard/kmip/servers.cfgfile:Show example of server configuration file contents
xxx.xxx.xxx.xxx:5696.host=xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx:5696.port=5696 xxx.xxx.xxx.xxx:5696.trusted_file=/cfcard/kmip/certs/CA.pem xxx.xxx.xxx.xxx:5696.protocol=KMIP1_4 1xxx.xxx.xxx.xxx:5696.timeout=25 xxx.xxx.xxx.xxx:5696.nbio=1 xxx.xxx.xxx.xxx:5696.cert_file=/cfcard/kmip/certs/client.crt xxx.xxx.xxx.xxx:5696.key_file=/cfcard/kmip/certs/client.key xxx.xxx.xxx.xxx:5696.ciphers="TLSv1.2:kRSA:!CAMELLIA:!IDEA:!RC2:!RC4:!SEED:!eNULL:!aNULL" xxx.xxx.xxx.xxx:5696.verify=true xxx.xxx.xxx.xxx:5696.netapp_keystore_uuid=<id_value>
If prompted, enter the ONTAP Cluster UUID from the partner node. You can check the cluster UUID from the partner node using the
cluster identify showcommand.Show example of ONTAP Cluster UUID prompt
Notice: bootarg.mgwd.cluster_uuid is not set or is empty. Do you know the ONTAP Cluster UUID? {y/n} y Enter the ONTAP Cluster UUID: <cluster_uuid_value> System is ready to utilize external key manager(s). -
If prompted, enter the temporary network interface and settings for the node:
The IP address for the port
The netmask for the port
The IP address of the default gateway
Show example of temporary network setting prompts
In order to recover key information, a temporary network interface needs to be configured. Select the network port you want to use (for example, 'e0a') e0M Enter the IP address for port : xxx.xxx.xxx.xxx Enter the netmask for port : xxx.xxx.xxx.xxx Enter IP address of default gateway: xxx.xxx.xxx.xxx Trying to recover keys from key servers.... [discover_versions] [status=SUCCESS reason= message=]
Verify the key restoration status:
If you see
kmip2_client: Successfully imported the keys from external key server: xxx.xxx.xxx.xxx:5696in the output, the EKM configuration has been successfully restored. The process restores the appropriate files from the partner node and reboots the node. Proceed to the next step. -
If the key is not successfully restored, the system halts and displays error and warning messages. Rerun the recovery process from the LOADER prompt:
boot_recovery -partnerShow example of key recovery error and warning messages
ERROR: kmip_init: halting this system with encrypted mroot... WARNING: kmip_init: authentication keys might not be available. ******************************************************** * A T T E N T I O N * * * * System cannot connect to key managers. * * * ******************************************************** ERROR: kmip_init: halting this system with encrypted mroot... . Terminated Uptime: 11m32s System halting... LOADER-B>
Return the controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_nameGo to re-enabling automatic giveback if it was disabled.
After you've restored the ONTAP image and the node is up and serving data, you return the failed part to NetApp.
