Replace an I/O module in an AFF C30 or AFF C60 system
Replace an I/O module in your AFF C30 or AFF C60 storage system when the module fails. The replacement process involves shutting down the controller, replacing the failed I/O module, rebooting the controller, and returning the failed part to NetApp.
All other components in the storage system must be functioning properly. If they are not, contact NetApp Support before continuing with this procedure.
If needed, you can turn on the storage system location (blue) LEDs to aid in physically locating the affected storage system. Log into the BMC using SSH and enter the system location-led on command.
A storage system has three location LEDs: one on the operator display panel and one on each controller. Location LEDs remain illuminated for 30 minutes.
You can turn them off by entering the system location-led off command. If you are unsure if the LEDs are on or off, you can check their state by entering the system location-led show command.
Step 1: Shut down the controller with the impaired I/O module
Shut down or take over the controller with the impaired I/O module using one of the following options.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a SAN system, you must have checked event messages (
cluster kernel-service show) for the impaired controller SCSI blade. Thecluster kernel-service showcommand (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback:
Enter the following command from the console of the healthy controller:
Enter
ywhen you see the prompt Do you want to disable auto-giveback?
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…
Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings you to the LOADER prompt.
You must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state:
metrocluster node show
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h -
Enter
Go to the next section.
ywhen prompted.System prompt or password prompt (enter system password)
Step 2: Replace a failed I/O module
To replace a failed I/O module, locate it in the controller and follow the specific sequence of steps.
Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches. |
Unplug cabling from the failed I/O module.
Make sure to label the cables so that you know where they came from.
Remove the failed I/O module from the controller:
Turn the I/O module thumbscrew counterclockwise to loosen.
Pull the I/O module out of the controller using the port label tab on the left and the thumbscrew.
Install the replacement I/O module into the target slot:
Align the I/O module with the edges of the slot.
Gently push the I/O module all the way into the slot, making sure to properly seat the module into the connector.
You can use the tab on the left and the thumbscrew to push in the I/O Module.
Turn the thumbscrew clockwise to tighten.
Cable the I/O module.
Step 3: Reboot the controller
After you replace an I/O module, you must reboot the controller.
Reboot the controller from the LOADER prompt:
byeRebooting the impaired controller also reinitializes the I/O modules and other components. -
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name -
Restore automatic giveback from the console of the healthy controller:
storage failover modify -node local -auto-giveback true -
If AutoSupport is enabled, restore automatic case creation:
Step 4: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
