Install and maintain
Replace the NVRAM in an AFF A70 or AFF A90 system
Contributors netapp-jsnyder dougthomp netapp-driley
Replace the NVRAM in your AFF A70 or AFF A90 system when the non-volatile memory becomes faulty or requires an upgrade. The replacement process involves shutting down the impaired controller, completely removing power by pulling the controller out a few inches, replacing the NVRAM module or the NVRAM DIMM, reassigning the disks, and returning the failed part to NetApp.
The NVRAM module consists of the NVRAM12 hardware and field-replaceable DIMMs. You can replace a failed NVRAM module or the DIMMs inside the NVRAM module.
Before you begin
  • Make sure you have the replacement part available. You must replace the failed component with a replacement component you received from NetApp.
  • Make sure all other components in the storage system are functioning properly; if not, contact NetApp Support.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller using one of the following options.
Option 1: Most systems
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Option 2: Controller is in a MetroCluster
  • You must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state:
    metrocluster node show
Steps
    cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
    The LOADER prompt
    Go to the next section.
    System prompt or password prompt (enter system password)
Step 2: Replace the NVRAM module or NVRAM DIMM
Replace the NVRAM module or NVRAM DIMMs using the appropriate option.
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
Warning The NVRAM module is not hot-swappable. Before replacing it, reseat the drives, shut down the node, unplug controller power, and pull the controller a few inches out of the chassis.
Option 1: Replace the NVRAM module
To replace the NVRAM module, locate it in slot 4/5 in the chassis and follow the specific sequence of steps.
  1. Ensure that all drives in the chassis are firmly seated against the midplane by using your thumbs to push each drive until you feel a positive stop.
    Video - Confirm drive seating
    Seat the drives
  2. Check the controller drives based on the system status:
    1. On the healthy controller, check if any active RAID group is in a degraded state, failed state, or both:
      storage aggregate show -raidstatus !*normal*
      • If the command returns There are no entries matching your query. continue to go to the next sub-step to check for missing drives.
      • If the command returns any other results, collect the AutoSupport data from both controllers and contact NetApp Support for further assistance.
        system node autosupport invoke -node * -type all -message '<message_name>'
    2. Check for missing drive issues for both the file system or spare drives:
      event log show -severity * -node * -message-name *disk.missing*
      • If the command returns There are no entries matching your query. continue to go to the next step.
  3. Go to the rear of the chassis.
  4. Unplug the controller's PSUs.
    Note If your system has DC power, disconnect the power block from the PSUs.
  5. Press down on both of the locking latches on the controller, rotate both latches downward at the same time and pull the controller out about 3 or 4 inches.
  6. Rotate the cable management tray down by pulling the buttons on the inside of the cable management tray and rotating it down.
  7. Remove the target NVRAM module from the chassis:
    1. Depress the cam latch button.
      The cam button moves away from the chassis.
    2. Rotate the cam latch as far as it will go.
    3. Remove the impaired NVRAM module from the chassis by hooking your finger into the cam lever opening and pulling the module out of the chassis.
      Remove the NVRAM12 module and DIMMs
      Callout number 1
      Cam locking button
      Callout number 2
      DIMM locking tabs
  8. Set the NVRAM module on a stable surface.
  9. Remove the DIMMs, one at a time, from the impaired NVRAM module and install them in the replacement NVRAM module.
  10. Install the replacement NVRAM module into the chassis:
    1. Align the module with the edges of the chassis opening in slot 4/5.
    2. Gently slide the module into the slot all the way, and then push the cam latch all the way up to lock the module in place.
  11. Reinstall the controller module. The controller reboots as soon as it is fully inserted.
    1. Firmly push the controller module into the chassis until it meets the midplane and is fully seated.
      The locking latches rise when the controller module is fully seated.
      Note Do not use excessive force when sliding the controller module into the chassis to avoid damaging the connectors.
    2. Rotate the locking latches upward into the locked position.
  12. Plug the power cords into the power supplies.
    Note If you have DC power supplies, reconnect the power block to the power supplies.
  13. Rotate the cable management tray up to the closed position.
  14. Return the impaired controller to normal operation by giving back its storage: storage failover giveback -ofnode impaired_node_name.
  15. If automatic giveback was disabled, reenable it: storage failover modify -node local -auto-giveback true .
  16. If AutoSupport is enabled, restore/unsuppress automatic case creation: system node autosupport invoke -node * -type all -message MAINT=END.
Option 2: Replace the NVRAM DIMM
To replace NVRAM DIMMs in the NVRAM module, first you must remove the NVRAM module and then replace the target DIMM.
  1. If you are not already grounded, properly ground yourself.
  2. Ensure that all drives in the chassis are firmly seated against the midplane by using your thumbs to push each drive until you feel a positive stop.
    Seat the drives
  3. Check the controller drives based on the system status:
  4. Go to the rear of the chassis.
  5. Unplug the controller's PSUs.
  6. Press down on both of the locking latches on the controller, rotate both latches downward at the same time and pull the controller out about 3 or 4 inches.
  7. Rotate the cable management tray down by gently pulling the pins on the ends of the tray and rotating the tray down.
  8. Remove the target NVRAM module from the chassis:
    1. Depress the cam button.
    3. Remove the NVRAM module from the chassis by hooking your finger into the cam lever opening and pulling the module out of the chassis.
      Callout number 1
      Cam locking button
      Callout number 2
      DIMM locking tabs
  9. Set the NVRAM module on a stable surface.
  10. Locate the DIMM to be replaced inside the NVRAM module.
    Note Consult the FRU map label on the side of the NVRAM module to determine the locations of DIMM slots 1 and 2.
  11. Remove the DIMM by pressing down on the DIMM locking tabs and lifting the DIMM out of the socket.
  12. Install the replacement DIMM by aligning the DIMM with the socket and gently pushing the DIMM into the socket until the locking tabs lock in place.
  13. Install the NVRAM module into the chassis:
    1. Gently slide the module into the slot until the cam latch begins to engage with the I/O cam pin, and then rotate the cam latch all the way up to lock the module in place.
  14. Reinstall the controller module. The controller reboots as soon as it is fully inserted.
  15. Plug the power cords into the power supplies.
  16. Rotate the cable management tray up to the closed position.
  17. Return the impaired controller to normal operation by giving back its storage: storage failover giveback -ofnode impaired_node_name.
  18. If automatic giveback was disabled, reenable it: storage failover modify -node local -auto-giveback true.
  19. If AutoSupport is enabled, restore/unsuppress automatic case creation: system node autosupport invoke -node * -type all -message MAINT=END.
Step 3: Reassign disks
You must confirm the system ID change when you boot the controller and then verify that the change was implemented.
Caution Disk reassignment is only needed when replacing the NVRAM module and does not apply to NVRAM DIMM replacement.
Steps
  1. If the controller is in Maintenance mode (showing the *> prompt), exit Maintenance mode and go to the LOADER prompt:
    halt
  2. From the LOADER prompt on the controller, boot the controller and enter y when prompted to override the system ID due to a system ID mismatch.
  3. Wait until the Waiting for giveback message is displayed on the console of the controller with the replacement module and then, from the healthy controller, verify that the new partner system ID has been automatically assigned:
    storage failover show
    In the command output, you should see a message that the system ID has changed on the impaired controller, showing the correct old and new IDs. In the following example, node 2 has undergone replacement and has a new system ID of 151759706.
    node1:> storage failover show
                                        Takeover
    Node              Partner           Possible     State Description
    node1             node2             false        System ID changed on partner (Old:
                                                      151759755, New: 151759706), In takeover
    node2             node1             -            Waiting for giveback (HA mailboxes)
  4. Give back the controller:
    1. From the healthy controller, give back the replaced controller's storage:
      storage failover giveback -ofnode replacement_node_name
      The controller takes back its storage and completes booting.
      If you are prompted to override the system ID due to a system ID mismatch, you should enter y.
      If the giveback is vetoed, you can consider overriding the vetoes.
      For more information, see manual giveback commands to override the veto.
    2. After the giveback has been completed, confirm that the HA pair is healthy and that takeover is possible: storage failover show
      The output from the storage failover show command should not include the System ID changed on partner message.
  5. Verify that the disks were assigned correctly:
    storage disk show -ownership
    The disks belonging to the controller should show the new system ID. In the following example, the disks owned by node1 now show the new system ID, 151759706:
    node1:> storage disk show -ownership
    Disk  Aggregate Home  Owner  DR Home  Home ID    Owner ID  DR Home ID Reserver  Pool
    1.0.0  aggr0_1  node1 node1  -        151759706  151759706  -       151759706 Pool0
    1.0.1  aggr0_1  node1 node1           151759706  151759706  -       151759706 Pool0
  6. If the system is in a MetroCluster configuration, monitor the status of the controller: metrocluster node show
    The MetroCluster configuration takes a few minutes after the replacement to return to a normal state, at which time each controller will show a configured state, with DR Mirroring enabled and a mode of normal. The metrocluster node show -fields node-systemid command output displays the old system ID until the MetroCluster configuration returns to a normal state.
  7. If the controller is in a MetroCluster configuration, depending on the MetroCluster state, verify that the DR home ID field shows the original owner of the disk if the original owner is a controller on the disaster site.
    This is required if both of the following are true:
  8. If your system is in a MetroCluster configuration, verify that each controller is configured: metrocluster node show - fields configuration-state
    node1_siteA::> metrocluster node show -fields configuration-state
    dr-group-id            cluster node           configuration-state
    1 node1_siteA          node1mcc-001           configured
    1 node1_siteA          node1mcc-002           configured
    1 node1_siteB          node1mcc-003           configured
    1 node1_siteB          node1mcc-004           configured
    4 entries were displayed.
  9. Verify that the expected volumes are present for each controller:
    vol show -node node-name
  10. If storage encryption is enabled, you must restore functionality.
  11. Return the impaired controller to normal operation by giving back its storage:
  12. If automatic giveback was disabled, reenable it:
  13. If AutoSupport is enabled, restore/unsuppress automatic case creation:
Step 4: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
