Overview of boot media replacement - AFF A800
PDF of this doc site
Creating your file...
Your file is ready
You must replace the failed component with a replacement FRU component you received from your provider.
It is important that you apply the commands in these steps on the correct controller:
The impaired controller is the controller on which you are performing maintenance.
The healthy controller is the HA partner of the impaired controller.
