Install and maintain
Learn about adding and replacing I/O modules in an AFF C30 or AFF C60 system
Contributors netapp-lisa netapp-jsnyder
The AFF C30 and AFF C60 storage systems offer flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding an I/O module is essential when upgrading network capabilities. Hot-swapping or replacing an I/O module is essential when addressing a failed module.
You can replace a failed I/O module in your storage system with the same type of I/O module or with a different type. You can hot-swap a cluster and HA I/O module when your storage system meets specific requirements. You can also add an I/O module to a storage system with available slots.
  • Add an I/O module
    Adding additional I/O modules can improve redundancy, helping to ensure that the storage system remains operational even if one I/O module fails.
  • Hot-swap an I/O module
    Hot-swapping certain I/O modules for an equivalent module can restore the storage system to its optimal operating state. Hot-swapping is done without having to perform a manual takeover.
    To use this procedure, your storage system must be running ONTAP 9.17.1 or later and meet specific system requirements.
  • Replace an I/O module
    Replacing a failing I/O module can restore the storage system to its optimal operating state.
