Install an AFF A800 system using detailed step-by-step instructions
Install your AFF A800 storage system using these detailed step-by-step instructions, from preparing the site to bringing up the ONTAP cluster.
Step 1: Prepare for installation
To install your AFF A800 system, you need to create an account and register the system. You also need to inventory the appropriate number and type of cables for your system and collect specific network information.
You need to have access to the NetApp Hardware Universe (HWU) for information about site requirements as well as additional information on your configured system. You might also want to have access to the Release Notes for your version of ONTAP for more information about this system.
You need to provide the following at your site:
Rack space for the storage system
4U in an HA configuration for the platform
2U for each NS224 storage shelf
Phillips #2 screwdriver
Additional networking cables to connect your system to your network switch and laptop or console with a Web browser
Unpack the contents of all boxes.
Record the system serial number from the controllers.
Set up your account:
Log in to your existing account or create an account.
Register (NetApp Product Registration) your system.
Download and install NetApp Downloads: Config Advisor on your laptop.
Inventory and make a note of the number and types of cables you received.
The following table identifies the types of cables you might receive. If you receive a cable not listed in the table, see the NetApp Hardware Universe to locate the cable and identify its use.
Connector type Part number and length Type of cable… For… 100 GbE cable
X66211A-05 (112-00595), 0.5m
X66211-1 (112-00573), 1m
X66211-2 (112-00574), 2m
X66211-5 (112-00576), 5m
HA interconnect
Cluster interconnect network
Storage, Data
10 GbE cable
X6566B-3-R6 (112-00300), 3m;
X6566B-5-R6 (112-00301), 5m
Data
25 GbE cable
X66240A-2 (112-00598), 2m;
X66240A-5 (112-00600), 5m
Data
RJ-45 (order dependent)
Not applicable
Management
Fibre Channel
X66250-2 (112-00342) 2m;
X66250-5 (112-00344) 5m;
X66250-15 (112-00346) 15m;
X66250-30 (112-00347) 30m
Network
Micro-USB console cable
Not applicable
Console connection during software setup
Power cables
Not applicable
Connecting the PSUs to power source
Download and complete the Cluster Configuration Worksheet.
Step 2: Install the hardware
You need to install your system in a 4-post rack or NetApp system cabinet, as applicable.
Install the rail kits, as needed.
Install and secure your system using the instructions included with the rail kit.
You need to be aware of the safety concerns associated with the weight of the system.
Attach cable management devices (as shown).
Place the bezel on the front of the system.
Step 3: Cable controllers
There is required cabling for your platform's cluster using the two-node switchless cluster method or the cluster interconnect network method. There is optional cabling to the Fibre Channel or iSCSI host networks or direct-attached storage. This cabling is not exclusive; you can have cabling to a host network and storage.
Required cabling: Cable controllers to a cluster
Cable the controllers to a cluster by using the two-node switchless cluster method or by using the cluster interconnect network.
Option 1: Cable a two-node switchless cluster
Management network ports on the controllers are connected to switches. The HA interconnect and cluster interconnect ports are cabled on both controllers.
Contact your network administrator for information about connecting the system to the switches.
Be sure to check the illustration arrow for the proper cable connector pull-tab orientation.
As you insert the connector, you should feel it click into place; if you do not feel it click, remove it, turn it around and try again. |
Use the animation or the tabulated steps to complete the cabling between the controllers and the switches:
Animation - Cable a two-node switchless clusterStep Perform on each controller module
Cable the HA interconnect ports:
e0b to e0b
e1b to e1b
Cable the cluster interconnect ports:
e0a to e0a
e1a to e1a
Cable the management ports to the management network switches
DO NOT plug in the power cords at this point.
To perform optional cabling, see:
To complete setting up your system, see Step 4: Complete system setup and configuration.
Option 2: Cable a switched cluster
Cluster interconnect and management network ports on the controllers are connected to switches while the HA interconnect ports are cabled on both controllers.
Animation - Cable a switched clusterStep Perform on each controller module
e0b to e0b
e1b to e1b
Cable the cluster interconnect ports to the 100 GbE cluster interconnect switches.
e0a
e1a
Optional cabling: Cable configuration-dependent options
You have configuration-dependent optional cabling to the Fibre Channel or iSCSI host networks or direct-attached storage. This cabling is not exclusive; you can have cabling to a host network and storage.
Option 1: Cable to a Fibre Channel host network
Fibre Channel ports on the controllers are connected to Fibre Channel host network switches.
| Step | Perform on each controller module |
1 |
Cable ports 2a through 2d to the FC host switches. |
2 |
To perform other optional cabling, choose from: |
3 |
To complete setting up your system, see Step 4: Complete system setup and configuration. |
Option 2: Cable to a 10GbE host network
10GbE ports on the controllers are connected to 10GbE host network switches.
1 |
Cable ports e4a through e4d to the 10GbE host network switches. |
2 |
3 |
Option 3: Cable the controllers to a single drive shelf
You must cable each controller to the NSM modules on the NS224 drive shelf.
Use the animation or the tabulated steps to cable your controllers to a single shelf:
Cable controller A to the shelf: |
Cable controller B to the shelf: |
Option 4: Cable the controllers to two drive shelves
You must cable each controller to the NSM modules on both NS224 drive shelves.
Use the animation or the tabulated steps to cable your controllers to two drive shelves:
Cable controller A to the shelves: |
Cable controller B to the shelves: |
Complete the system setup and configuration using cluster discovery with only a connection to the switch and laptop, or by connecting directly to a controller in the system and then connecting to the management switch.
Option 1: Complete system setup and configuration if network discovery is enabled
If you have network discovery enabled on your laptop, you can complete system setup and configuration using automatic cluster discovery.
Plug the power cords into the controller power supplies, and then connect them to power sources on different circuits.
The system begins to boot. Initial booting might take up to eight minutes.
Make sure that your laptop has network discovery enabled.
See your laptop's online help for more information.
Use the animation to connect your laptop to the Management switch:
Animation - Connect your laptop to the Management switch -
Select an ONTAP icon listed to discover:
Open File Explorer.
Select Network in the left pane and right-click and select refresh.
Double-click either ONTAP icon and accept any certificates displayed on your screen.
XXXXX is the system serial number for the target node. System Manager opens.
Use System Manager guided setup to configure your system using the data you collected in the ONTAP Configuration Guide.
Verify the health of your system by running Config Advisor.
After you have completed the initial configuration, go to ONTAP 9 documentation for information about configuring additional features in ONTAP.
Option 2: Complete system setup and configuration if network discovery is not enabled
If network discovery is not enabled on your laptop, you must complete the configuration and setup using this task.
Cable and configure your laptop or console:
Set the console port on the laptop or console to 115,200 baud with N-8-1.
See your laptop or console's online help for how to configure the console port. -
Connect the console cable to the laptop or console, and connect the console port on the controller using the console cable that came with your system.
Connect the laptop or console to the switch on the management subnet.
Assign a TCP/IP address to the laptop or console, using one that is on the management subnet.
Assign an initial node management IP address to one of the nodes.
If the management network has DHCP… Then… Configured
Record the IP address assigned to the new controllers.
Not configured
Open a console session using PuTTY, a terminal server, or the equivalent for your environment.
Check your laptop or console's online help if you do not know how to configure PuTTY. -
Enter the management IP address when prompted by the script.
Using System Manager on your laptop or console, configure your cluster:
Point your browser to the node management IP address.
The format for the address is https://x.x.x.x. -
Configure the system using the data you collected in the ONTAP Configuration Guide.
