Pre-shutdown checks for onboard encryption keys - AFF A900
Prior to shutting down the impaired controller and checking the status of the onboard encryption keys, you must check the status of the impaired controller, disable automatic giveback, and check the version of ONTAP that is running.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see the NetApp Encryption overview with the CLI.
Check the status of the impaired controller:
If the impaired controller is at the login prompt, log in as
admin
If the impaired controller is at the LOADER prompt and is part of HA configuration, log in as
admin
on the healthy controller. -
If the impaired controller is in a standalone configuration and at LOADER prompt, contact mysupport.netapp.com.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=number_of_hours_downh
The following AutoSupport message suppresses automatic case creation for two hours:
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
Check the version of ONTAP the system is running on the impaired controller if up, or on the partner controller if the impaired controller is down, using the
version -v
command:-
If <lno-DARE> or <1Ono-DARE> is displayed in the command output, the system does not support NVE, proceed to shut down the controller.
ONTAP 9.6 and later
Before shutting down the impaired controller, you need to verify whether the system has either NetApp Volume Encryption (NVE) or NetApp Storage Encryption (NSE) enabled. If so, you need to verify the configuration.
Verify whether NVE is in use for any volumes in the cluster:
volume show -is-encrypted true
If any volumes are listed in the output, NVE is configured and you need to verify the NVE configuration. If no volumes are listed, check whether NSE is configured and in use.
Verify whether NSE is configured and in use:
storage encryption disk show
If the command output lists the drive details with Mode & Key ID information, NSE is configured and you need to verify the NSE configuration and in use.
If no disks are shown, NSE is not configured.
If NVE and NSE are not configured, no drives are protected with NSE keys, it’s safe to shut down the impaired controller.
Verify NVE configuration
Display the key IDs of the authentication keys that are stored on the key management servers:
security key-manager key-query
After the ONTAP 9.6 release, you may have additional key manager types. The types are KMIP , AKV , and GCP . The process for confirming these types is the same as confirming external or onboard key manager types.
If the
Key Manager
type displaysexternal
and theRestored
column displaysyes
, it’s safe to shut down the impaired controller. -
If the
Key Manager
type displaysonboard
and theRestored
column displaysyes
, you need to complete some additional steps. -
If the
Key Manager
and theRestored
column displays anything other thanyes
If the
Key Manager
and theRestored
, you need to complete some additional steps.-
If the
Key Manager
and theRestored
column displaysyes
, manually back up the OKM information:-
Go to advanced privilege mode and enter
y
when prompted to continue:set -priv advanced
Enter the command to display the key management information:
security key-manager onboard show-backup
Copy the contents of the backup information to a separate file or your log file. You’ll need it in disaster scenarios where you might need to manually recover OKM.
Return to admin mode:
set -priv admin
Shut down the impaired controller.
If the
Key Manager
and theRestored
Restore the external key management authentication keys to all nodes in the cluster:
security key-manager external restore
If the command fails, contact NetApp Support.
Verify that the
Restored
column equalsyes
for all authentication keys:security key-manager key-query
If the
Key Manager
and theRestored
Enter the onboard security key-manager sync command:
security key-manager onboard sync
Enter the customer’s onboard key management passphrase at the prompt. If the passphrase cannot be provided, contact NetApp Support. mysupport.netapp.com -
Verify the
Restored
column showsyes
Verify that the
Key Manager
type showsonboard
, and then manually back up the OKM information. -
y
Enter the command to display the key management backup information:
set -priv admin
You can safely shut down the controller.
Verify NSE configuration
security key-manager key-query -key-type NSE-AK
If the
Key Manager
and theRestored
column displaysyes
If the
Key Manager
and theRestored
column displaysyes
If the
Key Manager
and theRestored
If the
Key Manager
and theRestored
If the
Key Manager
and theRestored
column displaysyes
y
set -priv admin
If the
Key Manager
and theRestored
security key-manager external sync
Verify that the
Restored
column equalsyes
If the
Key Manager
and theRestored
Verify the
Restored
column showsyes
Verify that the
Key Manager
type showsonboard
y
set -priv admin
