Replace the NVRAM in an ASA A70 or ASA A90 system
Replace the NVRAM in your ASA A70 or ASA A90 system when the non-volatile memory becomes faulty or requires an upgrade. The replacement process involves shutting down the impaired controller, completely removing power by pulling the controller out a few inches, replacing the NVRAM module or the NVRAM DIMM, reassigning the disks, and returning the failed part to NetApp.
The NVRAM module consists of the NVRAM12 hardware and field-replaceable DIMMs. You can replace a failed NVRAM module or the DIMMs inside the NVRAM module.
Make sure you have the replacement part available. You must replace the failed component with a replacement component you received from NetApp.
Make sure all other components in the storage system are functioning properly; if not, contact NetApp Support.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a SAN system, you must have checked event messages (
cluster kernel-service show) for the impaired controller SCSI blade. Thecluster kernel-service showcommand (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback:
Enter the following command from the console of the healthy controller:
Enter
ywhen you see the prompt Do you want to disable auto-giveback?
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…
Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings you to the LOADER prompt.
Step 2: Replace the NVRAM module or NVRAM DIMM
Replace the NVRAM module or NVRAM DIMMs using the appropriate option.
The NVRAM module is not hot-swappable. Before replacing it, reseat the drives, shut down the node, unplug controller power, and pull the controller a few inches out of the chassis. |
To replace the NVRAM module, locate it in slot 4/5 in the chassis and follow the specific sequence of steps.
Ensure that all drives in the chassis are firmly seated against the midplane by using your thumbs to push each drive until you feel a positive stop.
Go to the rear of the chassis. If you are not already grounded, properly ground yourself.
Unplug the controller's PSUs.
If your system has DC power, disconnect the power block from the PSUs. -
Press down on both of the locking latches on the controller, rotate both latches downward at the same time and pull the controller out about 3 or 4 inches.
Rotate the cable management tray down by pulling the buttons on the inside of the cable management tray and rotating it down.
Remove the target NVRAM module from the chassis:
Depress the cam latch button.
The cam button moves away from the chassis.
Rotate the cam latch as far as it will go.
Remove the impaired NVRAM module from the chassis by hooking your finger into the cam lever opening and pulling the module out of the chassis.
Cam locking button
DIMM locking tabs
Set the NVRAM module on a stable surface.
Remove the DIMMs, one at a time, from the impaired NVRAM module and install them in the replacement NVRAM module.
Install the replacement NVRAM module into the chassis:
Align the module with the edges of the chassis opening in slot 4/5.
Gently slide the module into the slot all the way, and then push the cam latch all the way up to lock the module in place.
Reinstall the controller module. The controller reboots as soon as it is fully inserted.
Firmly push the controller module into the chassis until it meets the midplane and is fully seated.
The locking latches rise when the controller module is fully seated.
Do not use excessive force when sliding the controller module into the chassis to avoid damaging the connectors. -
Rotate the locking latches upward into the locked position.
Plug the power cords into the power supplies.
If you have DC power supplies, reconnect the power block to the power supplies. -
Rotate the cable management tray up to the closed position.
To replace NVRAM DIMMs in the NVRAM module, you must remove the NVRAM module, and then replace the target DIMM.
Rotate the cable management tray down by gently pulling the pins on the ends of the tray and rotating the tray down.
Depress the cam button.
Remove the NVRAM module from the chassis by hooking your finger into the cam lever opening and pulling the module out of the chassis.
Cam locking button
DIMM locking tabs
Locate the DIMM to be replaced inside the NVRAM module.
Consult the FRU map label on the side of the NVRAM module to determine the locations of DIMM slots 1 and 2. -
Remove the DIMM by pressing down on the DIMM locking tabs and lifting the DIMM out of the socket.
Install the replacement DIMM by aligning the DIMM with the socket and gently pushing the DIMM into the socket until the locking tabs lock in place.
Install the NVRAM module into the chassis:
Gently slide the module into the slot until the cam latch begins to engage with the I/O cam pin, and then rotate the cam latch all the way up to lock the module in place.
Step 3: Verify controller state
You must confirm the controller state of the controllers connected to the disk pool when you boot the controller.
If the controller is in Maintenance mode (showing the
*>prompt), exit Maintenance mode and go to the LOADER prompt: halt -
From the LOADER prompt on the controller, boot the controller and enter y when prompted to override the system ID due to a system ID mismatch.
Wait until the Waiting for giveback… message is displayed on the console of the controller with the replacement module and then, from the healthy controller, verify the system state: storage failover show
In the command output, you should see a message indicates the state of the controllers.
Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------------------------- <nodename> <nodename>- true Connected to <nodename>-P2-3-178. P2-3-178 Waiting for cluster applications to come online on the local node. AFF-A90-NBC-P2-3-178 <nodename>- true Connected to <nodename>-P2-3-177, P2-3-177 Partial giveback 2 entries were displayed. -
Give back the controller:
From the healthy controller, give back the replaced controller's storage: storage failover giveback -ofnode replacement_node_name
The controller connects back its storage pool and completes booting.
If you are prompted to override the system ID due to a system ID mismatch, you should enter y.
If the giveback is vetoed, you can consider overriding the vetoes. For more information, see the Manual giveback commands topic to override the veto.
After the giveback has been completed, confirm that the HA pair is healthy and that takeover is possible: storage failover show
Verify all disks are displayed:
storage disk show::> storage disk show Usable Disk Container Container Disk Size Shelf Bay Type Type Name ---------------- ---------- ----- --- ------- ----------- --------- 1.0.0 3.49TB 0 0 SSD-NVM aggregate pod_NVME_SSD_1 1.0.1 3.49TB 0 1 SSD-NVM aggregate pod_NVME_SSD_1 1.0.2 3.49TB 0 2 SSD-NVM aggregate pod_NVME_SSD_1 1.0.3 3.49TB 0 3 SSD-NVM aggregate pod_NVME_SSD_1 1.0.4 3.49TB 0 4 SSD-NVM aggregate pod_NVME_SSD_1 [...] 48 entries were displayed.
Step 4: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
