Install and maintain
Replace a DIMM in an ASA A70 or ASA A90 system
Contributors netapp-jsnyder dougthomp
Replace a DIMM in your ASA A70 or ASA A90 system if excessive correctable or uncorrectable memory errors are detected. Such errors can prevent the storage system from booting ONTAP. The replacement process involves shutting down the impaired controller, removing it, replacing the DIMM, reinstalling the controller, and then returning the failed part to NetApp.
Before you begin
  • All other components in the system must be functioning properly; if not, you must contact technical support.
  • You must replace the failed component with a replacement FRU component you received from your provider.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Remove the controller module
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
Steps
  1. Ensure that all drives in the chassis are firmly seated against the midplane by using your thumbs to push each drive until you feel a positive stop.
    Video - Confirm drive seating
    Seat the drives
  2. Check the controller drives based on the system status:
    1. On the healthy controller, check if any active RAID group is in a degraded state, failed state, or both:
      storage aggregate show -raidstatus !*normal*
      • If the command returns There are no entries matching your query. continue to go to the next sub-step to check for missing drives.
      • If the command returns any other results, collect the AutoSupport data from both controllers and contact NetApp Support for further assistance.
        system node autosupport invoke -node * -type all -message '<message_name>'
    2. Check for missing drive issues for both the file system or spare drives:
      event log show -severity * -node * -message-name *disk.missing*
      • If the command returns There are no entries matching your query. continue to go to the next step.
  3. Check the amber NVRAM that status LED located in slot 4/5 on the back of the impaired controller module is off. Look for the NV icon.
    NVRAM attention and status LED location graphic
    Callout number 1
    NVRAM status LED
    Callout number 2
    NVRAM attention LED
    • If the NV LED is off, go to the next step.
    • If the NV LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact Technical Support for assistance.
  4. If you are not already grounded, properly ground yourself.
  5. Unplug the controller module power supply cables from the controller module power supplies (PSU).
    Note If your system has DC power, disconnect the power block from the PSUs.
  6. Unplug the system cables and SFP and QSFP modules (if needed) from the controller module, keeping track of where the cables were connected.
    Leave the cables in the cable management device so that when you reinstall the cable management device, the cables are organized.
  7. Remove the cable management device from the controller module.
  8. Press down on both of the locking latches, and then rotate both latches downward at the same time.
    The controller module moves slightly out of the chassis.
    Controller remove graphic
    Callout number 1
    Locking latch
    Callout number 2
    Locking pin
  9. Slide the controller module out of the chassis and place it on a flat, stable surface.
    Make sure that you support the bottom of the controller module as you slide it out of the chassis.
Step 3: Replace a DIMM
To replace the DIMMs, locate them inside the controller and follow the specific sequence of steps.
Steps
  1. If you are not already grounded, properly ground yourself.
  2. Open the controller air duct on the top of the controller.
    1. Insert your fingers in the recesses at the far ends of the air duct.
    2. Lift the air duct and rotate it upward as far as it will go.
  3. Locate the DIMMs on your controller module and identify the target DIMM.
    Use the FRU map on the controller airduct to locate the DIMM slot.
  4. Eject the DIMM from its slot by slowly pushing apart the two DIMM ejector tabs on either side of the DIMM, and then slide the DIMM out of the slot.
    Important Carefully hold the DIMM by the edges to avoid pressure on the components on the DIMM circuit board.
    DIMM replace
    Callout number 1
    DIMM and DIMM ejector tabs
  5. Remove the replacement DIMM from the antistatic shipping bag, hold the DIMM by the corners, and align it to the slot.
    The notch among the pins on the DIMM should line up with the tab in the socket.
  6. Make sure that the DIMM ejector tabs on the connector are in the open position, and then insert the DIMM squarely into the slot.
    The DIMM fits tightly in the slot, but should go in easily. If not, realign the DIMM with the slot and reinsert it.
    Important Visually inspect the DIMM to verify that it is evenly aligned and fully inserted into the slot.
  7. Push carefully, but firmly, on the top edge of the DIMM until the ejector tabs snap into place over the notches at the ends of the DIMM.
  8. Close the controller air duct.
Step 4: Reinstall the controller module
Reinstall the controller module and reboot it.
Steps
  1. Ensure the air duct is completely closed by rotating it down as far as it will go.
    It must lie flush against the controller module sheet metal.
  2. Align the end of the controller module with the opening in the chassis, and then gently push the controller module halfway into the system.
    Note Do not completely insert the controller module in the chassis until instructed to do so.
  3. Recable the storage system, as needed.
    If you removed the transceivers (QSFPs or SFPs), remember to reinstall them if you are using fiber optic cables.
    Make sure that the console cable is connected to the repaired controller module so that it receives console messages when it reboots. The repaired controller receives power from the healthy controller and begins to reboot as soon as it is seated completely in the chassis.
  4. Complete the reinstallation of the controller module:
    1. Firmly push the controller module into the chassis until it meets the midplane and is fully seated.
      The locking latches rise when the controller module is fully seated.
      Do not use excessive force when sliding the controller module into the chassis to avoid damaging the connectors.
    2. Rotate the locking latches upward into the locked position.
  5. Plug the power cords into the power supplies. The controller reboots as soon as power is restored.
    If you have DC power supplies, reconnect the power block to the power supplies after the controller module is fully seated in the chassis.
  6. Return the impaired controller to normal operation by giving back its storage:
    storage failover giveback -ofnode impaired_node_name.
  7. If automatic giveback was disabled, reenable it:
    storage failover modify -node local -auto-giveback true.
  8. If AutoSupport is enabled, restore/unsuppress automatic case creation:
    system node autosupport invoke -node * -type all -message MAINT=END.
Step 5: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
