Install and maintain
ONTAP hardware and software compatibility
Contributors netapp-jsnyder
ONTAP storage systems are compatible with several versions of ONTAP software. Learn about the ONTAP versions that your storage systems and drive shelves support.
Full configuration support and limitations for ONTAP hardware systems are available in NetApp Hardware Universe. Details about known issues, limitations, and upgrade cautions in ONTAP 9 software are available in the ONTAP 9 Release Notes.
AFF systems
The AFF A-Series and AFF C-Series systems provide a robust, scale-out platform tailored for virtualized environments. They can be deployed as standalone systems or as high-performance tiers in NetApp ONTAP configurations. Learn more about AFF A-Series systems and AFF C-Series systems.
AFF A-Series and AFF C-Series systems are supported beginning in the following ONTAP releases.
ONTAP 9.16.1
  • AFF A20
  • AFF A30
  • AFF A50
  • AFF C30
  • AFF C60
  • AFF C80
ONTAP 9.15.1
  • AFF A1K
  • AFF A70
  • AFF A90
ONTAP 9.12.1P1
  • AFF A150
  • AFF C250
  • AFF C400
  • AFF C800
ONTAP 9.10.1
  • AFF A900
ONTAP 9.8
  • AFF A250
ONTAP 9.7
  • AFF A400
  • AFF A800
AFX systems
AFX systems provide a disaggregated solution engineered to meet the rigorous requirements of high-performance NAS and S3 workloads, including AI/ML applications. Learn more about the AFX system.
AFX systems are supported beginning in the following ONTAP release.
ONTAP 9.17.1
  • AFX 1K
ONTAP 9.19.1
  • AFX 2K
ASA r2 systems
ASA r2 systems deliver a unified hardware and software solution that creates a simplified experience specific to the needs of SAN-only customers. Learn more about the ASA r2 systems.
ASA r2 systems are supported beginning in the following ONTAP releases.
ONTAP 9.16.1
  • ASA A20
  • ASA A30
  • ASA A50
  • ASA C30
ONTAP 9.16.0
  • ASA A1K
  • ASA A70
  • ASA A90
ASA systems
ASA A-Series and ASA C-Series systems deliver a simplified and dedicated SAN experience that provides continuous data availability for enterprise mission critical databases and other SAN workloads using FCP or iSCSI protocol. Learn more about the ASA systems.
ASA systems are supported beginning in the following ONTAP releases.
ONTAP 9.13.1P1
  • ASA C250
  • ASA C400
  • ASA C800
ONTAP 9.13.1
  • ASA A150
  • ASA A250
  • ASA A400
  • ASA A900
ONTAP 9.8
  • ASA AFF A250
  • ASA AFF A800
ONTAP 9.7
  • ASA AFF A400
FAS systems
FAS systems deliver efficient and secure secondary storage - the ultimate solution for tiering, backup, and disaster recovery. Learn more about FAS systems.
FAS systems are supported beginning in the following ONTAP releases.
ONTAP 9.16.1
  • FAS50
ONTAP 9.15.1
  • FAS70
  • FAS90
ONTAP 9.13.1
  • FAS2820
ONTAP 9.11.1
  • FAS9500
ONTAP 9.10.1P3
  • FAS9500
ONTAP 9.7
  • FAS2750
  • FAS8300
  • FAS8700
Drive shelves
Drive shelves are specifically designed for NetApp AFF, AFX, ASA, and FAS systems and help deliver the performance, resiliency, and flexibility your digital transformation needs.
Drive shelves are available beginning with the following ONTAP releases.
ONTAP 9.17.1
  • NSX224 shelf for AFX systems
ONTAP 9.16.1
  • DCM3 for SAS-3 shelves
  • NS224 with NSM100B modules
ONTAP 9.6
NS224 shelf with NSM100 modules
