Install and maintain
Replace the real-time clock battery in an ASA A70 or ASA A90 system
Contributors netapp-jsnyder dougthomp
Replace the real-time clock (RTC) battery, commonly known as a coin cell battery, in your ASA A70 or ASA A90 system to ensure that services and applications relying on accurate time synchronization remain operational.
You can use this procedure with all versions of ONTAP supported by your system.
Make sure all other components in the system are functioning properly; if not, you must contact technical support.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Remove the controller module
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
Steps
  1. Ensure that all drives in the chassis are firmly seated against the midplane by using your thumbs to push each drive until you feel a positive stop.
    Video - Confirm drive seating
    Seat the drives
  2. Check the controller drives based on the system status:
    1. On the healthy controller, check if any active RAID group is in a degraded state, failed state, or both:
      storage aggregate show -raidstatus !*normal*
      • If the command returns There are no entries matching your query. continue to go to the next sub-step to check for missing drives.
      • If the command returns any other results, collect the AutoSupport data from both controllers and contact NetApp Support for further assistance.
        system node autosupport invoke -node * -type all -message '<message_name>'
    2. Check for missing drive issues for both the file system or spare drives:
      event log show -severity * -node * -message-name *disk.missing*
      • If the command returns There are no entries matching your query. continue to go to the next step.
  3. Check the amber NVRAM that status LED located in slot 4/5 on the back of the impaired controller module is off. Look for the NV icon.
    NVRAM attention and status LED location graphic
    Callout number 1
    NVRAM status LED
    Callout number 2
    NVRAM attention LED
    • If the NV LED is off, go to the next step.
    • If the NV LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact Technical Support for assistance.
  4. If you are not already grounded, properly ground yourself.
  5. Unplug the controller module power supply cables from the controller module power supplies (PSU).
    Note If your system has DC power, disconnect the power block from the PSUs.
  6. Unplug the system cables and SFP and QSFP modules (if needed) from the controller module, keeping track of where the cables were connected.
    Leave the cables in the cable management device so that when you reinstall the cable management device, the cables are organized.
  7. Remove the cable management device from the controller module.
  8. Press down on both of the locking latches, and then rotate both latches downward at the same time.
    The controller module moves slightly out of the chassis.
    Controller remove graphic
    Callout number 1
    Locking latch
    Callout number 2
    Locking pin
  9. Slide the controller module out of the chassis and place it on a flat, stable surface.
    Make sure that you support the bottom of the controller module as you slide it out of the chassis.
Step 3: Replace the RTC battery
Remove failed RTC battery and install the replacement RTC battery.
Steps
  1. Open the controller air duct on the top of the controller.
    1. Insert your fingers in the recesses at the far ends of the air duct.
    2. Lift the air duct and rotate it upward as far as it will go.
  2. Locate the RTC battery under the air duct.
    Callout number 1
    RTC battery and housing
  3. Gently push the battery away from the holder, rotate it away from the holder, and then lift it out of the holder.
    Note the polarity of the battery as you remove it from the holder. The battery is marked with a plus sign and must be positioned in the holder correctly. A plus sign near the holder tells you how the battery should be positioned.
  4. Remove the replacement battery from the antistatic shipping bag.
  5. Note the polarity of the RTC battery, and then insert it into the holder by tilting the battery at an angle and pushing down.
  6. Visually inspect the battery to make sure that it is completely installed into the holder and that the polarity is correct.
Step 4: Reinstall the controller module
Reinstall the controller module and reboot it.
Steps
  1. Ensure the air duct is completely closed by rotating it down as far as it will go.
    It must lie flush against the controller module sheet metal.
  2. Align the end of the controller module with the opening in the chassis, and then gently push the controller module halfway into the system.
    Note Do not completely insert the controller module in the chassis until instructed to do so.
  3. Recable the storage system, as needed.
    If you removed the transceivers (QSFPs or SFPs), remember to reinstall them if you are using fiber optic cables.
    Make sure that the console cable is connected to the repaired controller module so that it receives console messages when it reboots. The repaired controller receives power from the healthy controller and begins to reboot as soon as it is seated completely in the chassis.
  4. Complete the reinstallation of the controller module:
    1. Firmly push the controller module into the chassis until it meets the midplane and is fully seated.
      The locking latches rise when the controller module is fully seated.
      Do not use excessive force when sliding the controller module into the chassis to avoid damaging the connectors.
    2. Rotate the locking latches upward into the locked position.
  5. Plug the power cords into the power supplies. The controller reboots as soon as power is restored.
    If you have DC power supplies, reconnect the power block to the power supplies after the controller module is fully seated in the chassis.
  6. Return the impaired controller to normal operation by giving back its storage:
    storage failover giveback -ofnode impaired_node_name.
  7. If automatic giveback was disabled, reenable it:
    storage failover modify -node local -auto-giveback true.
  8. If AutoSupport is enabled, restore/unsuppress automatic case creation:
    system node autosupport invoke -node * -type all -message MAINT=END.
Step 5: Reset the time and date on the controller
After you replace the RTC battery, insert the controller, and power on for the first BIOS reset, you will see the following error messages:
RTC date/time error. Reset date/time to default
RTC power failure error
These messages are expected and you can continue with this procedure.
Steps
  1. Check the date and time on the healthy controller with the cluster date show command.
    If your system stops at the boot menu, select the option for Reboot node and respond y when prompted, then boot to LOADER by pressing Ctrl-C
    1. At the LOADER prompt on the target controller, check the time and date with the cluster date show command.
    2. If necessary, modify the date with the set date mm/dd/yyyy command.
    3. If necessary, set the time, in GMT, using the set time hh:mm:ss command.
  2. Confirm the date and time on the target controller.
  3. At the LOADER prompt, enter bye to reinitialize the PCIe cards and other components and let the controller reboot.
Step 6: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
