Install and maintain
AFF A70 and AFF A90 chassis replacement workflow
Contributors netapp-jsnyder dougthomp netapp-lisa
Get started with replacing the chassis of your AFF A70 or AFF A90 storage system by reviewing the replacement requirements, shutting down the controllers, replacing the chassis, and verifying system operations.
Review the chassis replacement requirements, including system compatibility, required tools, ONTAP credentials, and component functionality verification.
Prepare for the chassis replacement by locating the system, gathering credentials and tools, verifying the replacement chassis, and labeling cables.
Shut down the controllers to perform chassis maintenance safely.
Move the components from the impaired chassis to the replacement chassis.
Complete the replacement by booting the controllers, performing giveback, and returning the failed chassis to NetApp.
