Install and maintain
Quick start for ONTAP hardware systems
Contributors netapp-jsnyder netapp-martyh dougthomp
To get up and running with ONTAP hardware systems, you install hardware components, cable your hardware, and configure your storage in ONTAP.
If your system is in a MetroCluster configuration, go to the MetroCluster doc site and follow the install instructions applicable to your MetroCluster configuration type.
Use the following workflow to deploy your storage system when it is not set up in a MetroCluster configuration.
One Install switches
Install your switches in the rack or cabinet. Access the following instructions for your switch model.
Two Install the storage system and storage shelves
Install your storage system and storage shelves in the cabinet or rack. Access the install and setup instructions for your platform model.
Three Connect cables
Cable the controllers to your network and then cable the controllers to your shelves. The install and setup instructions for your platform model include instructions for cabling the controller ports to your network and to your switches.
Four Set up your ONTAP cluster
After you have installed and set up your controllers and switches, you must complete configuring your storage in ONTAP. Access the following instructions according to your deployment configuration.
