Restore and verify the controller configuration in an AFF A900 system
After completing the hardware replacement and booting to Maintenance mode, verify the low-level system configuration of the replacement controller and reconfigure system settings as necessary.
After completing the hardware replacement, you verify the low-level system configuration of the replacement controller, and reconfigure system settings as necessary.
Step 1: Set and verify the system time
You should check the time and date on the replacement controller module against the healthy controller module in an HA pair, or against a reliable time server in a stand-alone configuration. If the time and date do not match, you must reset them on the replacement controller module to prevent possible outages on clients due to time differences.
It is important that you apply the commands in the steps on the correct systems:
The replacement node is the new node that replaced the impaired node as part of this procedure.
The healthy node is the HA partner of the replacement node.
If the replacement node is not at the LOADER prompt, halt the system to the LOADER prompt.
On the healthy node, check the system time:
cluster date showThe date and time are based on the configured timezone.
At the LOADER prompt, check the date and time on the replacement node:
show dateThe date and time are given in GMT.
If necessary, set the date in GMT on the replacement node:
set date mm/dd/yyyy -
If necessary, set the time in GMT on the replacement node:
set time hh:mm:ss -
At the LOADER prompt, confirm the date and time on the replacement node:
Step 2: Verify and set the controller's HA state
You must verify the HA state of the controller module and, if necessary, update the state to match your system configuration.
In Maintenance mode from the replacement controller module, verify that all components display the same
HAstate:ha-config showIf your system is in… The HA state for all components should be… An HA pair
ha
A MetroCluster FC configuration with four or more nodes
mcc
A MetroCluster IP configuration
mccip
If the displayed system state of the controller module does not match your system configuration, set the
HAstate for the controller module:ha-config modify controller ha-state -
If the displayed system state of the chassis does not match your system configuration, set the
HAstate for the chassis:ha-config modify chassis ha-state
