Replace the controller in an AFF A70 or AFF A90 system
Replace the controller in your AFF A70 or AFF A90 system when a hardware failure requires it. The replacement process involves removing the impaired controller, moving the components to the replacement controller, installing the replacement controller, and rebooting it.
Step 1: Remove the controller module
Remove the controller module from the chassis before replacing it or an internal component.
Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches. |
Ensure that all drives in the chassis are firmly seated against the midplane by using your thumbs to push each drive until you feel a positive stop.
Video - Confirm drive seating -
Check the controller drives based on the system status:
On the healthy controller, check if any active RAID group is in a degraded state, failed state, or both:
storage aggregate show -raidstatus !*normal*-
If the command returns
There are no entries matching your query.continue to go to the next sub-step to check for missing drives. -
If the command returns any other results, collect the AutoSupport data from both controllers and contact NetApp Support for further assistance.
system node autosupport invoke -node * -type all -message '<message_name>'
Check for missing drive issues for both the file system or spare drives:
event log show -severity * -node * -message-name *disk.missing*-
There are no entries matching your query.continue to go to the next step. -
Check the amber NVRAM that status LED located in slot 4/5 on the back of the impaired controller module is off. Look for the NV icon.
NVRAM status LED
NVRAM attention LED
If the NV LED is off, go to the next step.
If the NV LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact Technical Support for assistance.
If you are not already grounded, properly ground yourself.
Unplug the controller module power supply cables from the controller module power supplies (PSU).
If your system has DC power, disconnect the power block from the PSUs. -
Unplug the system cables and SFP and QSFP modules (if needed) from the controller module, keeping track of where the cables were connected.
Leave the cables in the cable management device so that when you reinstall the cable management device, the cables are organized.
Remove the cable management device from the controller module.
Press down on both of the locking latches, and then rotate both latches downward at the same time.
The controller module moves slightly out of the chassis.
Locking latch
Locking pin
Slide the controller module out of the chassis and place it on a flat, stable surface.
Make sure that you support the bottom of the controller module as you slide it out of the chassis.
Step 2: Move the power supplies
Move the power supplies to the replacement controller.
Rotate the cam handle such that it can be used to pull power supply out of the controller module while pressing the locking tab.
The power supply is short. Always use two hands to support it when removing it from the controller module so that it does not suddenly swing free from the controller module and injure you.
Terracotta PSU locking tab
Power supply
Move the power supply to the new controller module, and then install it.
Using both hands, support and align the edges of the power supply with the opening in the controller module, and then gently push the power supply into the controller module until the locking tab clicks into place.
The power supplies will only properly engage with the internal connector and lock in place one way.
To avoid damaging the internal connector, do not use excessive force when sliding the power supply into the system.
Step 3: Move the fans
Move the fans modules to the replacement controller module.
Remove the fan module by pinching the locking tabs on the side of the fan module, and then lifting the fan module straight out of the controller module.
Fan locking tabs
Fan module
Move the fan module to the replacement controller module, and then install it by aligning its edges with the opening in the controller module and sliding it in until the locking latches click into place.
Repeat these steps for the remaining fan modules.
Step 4: Move the NV battery
Move the NV battery to the replacement controller module.
Open the air duct cover in the middle of the controller module and locate the NV battery.
NV battery air duct
NV battery pack plug
Attention: The NV module LED blinks while destaging contents to the flash memory when you halt the system. After the destage is complete, the LED turns off.
Lift the battery up to access the battery plug.
Squeeze the clip on the face of the battery plug to release the plug from the socket, and then unplug the battery cable from the socket.
Lift the battery out of the air duct and controller module.
Move the battery pack to the replacement controller module and then install it in the replacement controller module:
Open the NV battery air duct in the replacement controller module.
Plug the battery plug into the socket and make sure that the plug locks into place.
Insert the battery pack into the slot and press firmly down on the battery pack to make sure that it is locked into place.
Close the NV battery air duct.
Step 5: Move system DIMMs
Move the DIMMs to the replacement controller module.
Open the controller air duct on the top of the controller.
Insert your fingers in the recesses at the far ends of the air duct.
Lift the air duct and rotate it upward as far as it will go.
Locate the system DIMMs on the motherboard, using the DIMM map on top of the air duct.
The DIMM locations, by model, are listed in the following table:
Model
DIMM slot location
FAS70
3, 10, 19, 26
FAS90
3, 7, 10, 14, 19, 23, 26, 30
System DIMM
Note the orientation of the DIMM in the socket so that you can insert the DIMM in the replacement controller module in the proper orientation.
Eject the DIMM from its slot by slowly pushing apart the two DIMM ejector tabs on either side of the DIMM, and then slide the DIMM out of the slot.
Carefully hold the DIMM by the edges to avoid pressure on the components on the DIMM circuit board. -
Locate the slot on the replacement controller module where you are installing the DIMM.
Insert the DIMM squarely into the slot.
The DIMM fits tightly in the slot, but should go in easily. If not, realign the DIMM with the slot and reinsert it.
Visually inspect the DIMM to verify that it is evenly aligned and fully inserted into the slot. -
Push carefully, but firmly, on the top edge of the DIMM until the ejector tabs snap into place over the notches at the ends of the DIMM.
Repeat these steps for the remaining DIMMs.
Close the controller air duct.
Step 6: Move the I/O modules
Move the I/O modules to the replacement controller module.
Unplug any cabling on the target I/O module.
Make sure that you label the cables so that you know where they came from.
Rotate the cable management arm down by pulling the buttons on the inside of the cable management arm and rotating it down.
I/O module cam lever
Remove the I/O modules from the controller module:
Depress the target I/O module cam latch button.
Rotate the cam latch down as far as it will go. For horizontal modules, rotate the cam away from the module as far as it will go.
Remove the module from the controller module by hooking your finger into the cam lever opening and pulling the module out of the controller module.
Make sure that you keep track of which slot the I/O module was in.
Install the replacement I/O module into the replacement controller module by gently sliding the I/O module into the slot until the I/O cam latch begins to engage with the I/O cam pin, and then push the I/O cam latch all the way up to lock the module in place.
Repeat these steps to move the remaining I/O modules, except the modules in slots 6 and 7, to the replacement controller module.
To move the I/O modules from slots 6 and 7, you must move the carrier containing these I/O modules from the impaired controller module to the replacement controller module. -
Move the carrier containing the I/O modules in slots 6 and 7 to the replacement controller module:
Press the button on the right-most handle on the carrier handle. ..Slide the carrier out of the impaired controller module insert it into the replacement controller module in the same position it was in the impaired controller module.
Gently push the carrier all the way into the replacement controller module until it locks into place.
Step 7: Move the System Management module
Move the System Management module to the replacement controller module.
Remove the System Management module from the impaired controller module:
System Management module cam latch
Depress the system management cam button.
Rotate the cam lever all the way down.
Loop your finger into the cam lever and pull the module straight out of the system.
Install the system management module into the replacement controller module in the same slot that it was in on the impaired controller module:
Align the edges of the System Management module with the system opening and gently push it into the controller module.
Gently slide the module into the slot until the cam latch begins to engage with the I/O cam pin, and then rotate the cam latch all the way up to lock the module in place.
Step 8: Move the NVRAM module
Move the NVRAM module to the replacement controller module.
Remove the NVRAM module from the impaired controller module:
Cam locking button
DIMM locking tab
Depress the cam latch button.
The cam button moves away from the chassis.
Rotate the cam latch as far as it will go.
Remove the NVRAM module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the enclosure.
Install the NVRAM module into slot 4/5 in the replacement controller module:
Align the module with the edges of the chassis opening in slot 4/5.
Gently slide the module into the slot all the way, and then push the cam latch all the way up to lock the module in place.
Step 9: Install the controller module
Reinstall the controller module and reboot it.
Ensure the air duct is completely closed by rotating it down as far as it will go.
It must lie flush against the controller module sheet metal.
Align the end of the controller module with the opening in the chassis, and then gently push the controller module halfway into the system.
Do not completely insert the controller module in the chassis until instructed to do so. -
Reinstall the cable management arm, if removed, but do not reconnect any cables to the replacement controller.
Plug the console cable into the console port of the replacement controller module and reconnect it to the laptop so that so that it receives console messages when it reboots.
Complete the reinstallation of the controller module:
Firmly push the controller module into the chassis until it meets the midplane and is fully seated.
The locking latches rise when the controller module is fully seated.
Do not use excessive force when sliding the controller module into the chassis to avoid damaging the connectors. -
Rotate the locking latches upward into the locked position.
Plug in the power supplies. The controller boots to the LOADER prompt as soon as power is restored.
From the LOADER prompt, enter
show dateto display the date and time on the replacement controller. Date and time are in GMT.Time displayed is local time not always GMT and is displayed in 24hr mode. -
Set the current time in GMT with the
set time hh:mm:sscommand. You can get the current GMT from the partner node the `date -u`command. -
Recable the storage system, as needed.
If you removed the transceivers (QSFPs or SFPs), remember to reinstall them if you are using fiber optic cables.
Plug the power cords into the power supplies.
If you have DC power supplies, reconnect the power block to the power supplies after the controller module is fully seated in the chassis.
After you've replaced the impaired AFF A70 or AFF A90 controller, you need to restore the system configuration.
