Install and maintain
Learn about adding and replacing I/O modules in an ASA A1K system
Contributors netapp-jsnyder dougthomp netapp-lisa
The ASA A1K system offers flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding an I/O module is essential when upgrading network capabilities. Replacing an I/O module is essential when addressing a failed module.
You can replace a failed I/O module in your ASA A1K storage system with the same type of I/O module, or with a different kind of I/O module. You can also add an I/O module into a system with empty slots.
  • Add an I/O module
    Adding additional modules can improve redundancy, helping to ensure that the system remains operational even if one module fails.
  • Hot swap an I/O module
    Hot swapping an I/O module allows you to replace a failed module without shutting down the system, minimizing downtime and maintaining system availability.
  • Replace an I/O module
    Replacing a failing I/O module can restore the system to its optimal operating state.
I/O slot numbering
The I/O slots on ASA A1K controllers are numbered 1 through 11, as shown in the following illustration.
Slot numbering on an ASA A1K controller
