Install and maintain
Add an I/O module to an ASA A1K system
Contributors netapp-jsnyder dougthomp netapp-lisa
Add an I/O module to your ASA A1K system to enhance network connectivity and expand your system’s ability to handle data traffic.
You can add an I/O module to your ASA A1K storage system when there are empty slots available or when all slots are fully populated. .About this task
If needed, you can turn on the storage system location (blue) LEDs to aid in physically locating the affected storage system. Log into the BMC using SSH and enter the system location-led on command.
A storage system has two location LEDs, one on each controller. Location LEDs remain illuminated for 30 minutes.
You can turn them off by entering the system location-led off command. If you are unsure if the LEDs are on or off, you can check their state by entering the system location-led show command.
Step 1: Shut down the impaired controller module
Shut down or take over the impaired controller module.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Add the new I/O module
If the storage system has available slots, install the new I/O module into one of the available slots. If all slots are occupied, remove an existing I/O module to make space and then install the new one.
Before you begin
  • Check the NetApp Hardware Universe to make sure that the new I/O module is compatible with your storage system and version of ONTAP you're running.
  • If multiple slots are available, check the slot priorities in NetApp Hardware Universe and use the best one available for your I/O module.
  • Make sure that all other components are functioning properly.
  • Make sure you have the replacement component you received from NetApp.
Add I/O module to an available slot
You can add a new I/O module into a storage system with available slots.
Steps
  1. If you are not already grounded, properly ground yourself.
  2. Rotate the cable management tray down by pulling the buttons on the inside of the cable management tray and rotating it down.
  3. Remove the target slot blanking module from the carrier:
    1. Depress the cam latch on the blanking module in the target slot.
    2. Rotate the cam latch away from the module as far as it will go.
    3. Remove the module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the enclosure.
  4. Install the I/O module:
    1. Align the I/O module with the edges of the enclosure slot opening.
    2. Gently slide the module into the slot all the way into the enclosure, and then rotate the cam latch all the way up to lock the module in place.
  5. Cable the I/O module to the designated device.
    Note Make sure that any unused I/O slots have blanks installed to prevent possible thermal issues.
  6. Rotate the cable management tray up to the closed position.
  7. From the LOADER prompt, reboot the node:
    bye
    Note This reinitializes the I/O module and other components and reboots the node.
  8. Give back the controller from the partner controller:
    storage failover giveback -ofnode target_node_name
  9. Repeat these steps for controller B.
  10. From the healthy node, restore automatic giveback if you disabled it:
  11. If AutoSupport is enabled, restore automatic case creation:
Add I/O module to a fully-populated system
You can add an I/O module to a fully-populated system by removing an existing I/O module and installing a new one in its place.
About this task
Make sure you understand the following scenarios for adding a new I/O module to a fully-populated system:
Scenario Action required
NIC to NIC (same number of ports)
The LIFs will automatically migrate when its controller module is shut down.
NIC to NIC (different number of ports)
Permanently reassign the selected LIFs to a different home port. See Migrating a LIF for more information.
NIC to storage I/O module
Use System Manager to permanently migrate the LIFs to different home ports, as described in Migrating a LIF.
Steps
  2. Unplug any cabling on the target I/O module.
  3. Rotate the cable management tray down by pulling the buttons on the inside of the cable management tray and rotating it down.
  4. Remove the target I/O module from the chassis:
    1. Depress the cam latch button.
      Make sure that you keep track of which slot the I/O module was in.
  5. Install the I/O module into the target slot in the enclosure:
    1. Align the module with the edges of the enclosure slot opening.
  6. Cable the I/O module to the designated device.
  7. Repeat the remove and install steps to replace additional modules for the controller.
  8. Rotate the cable management tray up to the closed position.
  9. Reboot the controller from the LOADER prompt:_bye_
    This reinitializes the PCIe cards and other components and reboots the node.
  10. Give back the controller from the partner controller:
  11. Enable automatic giveback if it was disabled:
  12. Do one of the following:
    • If you removed a NIC I/O module and installed a new NIC I/O module, use the following network command for each port:
      storage port modify -node *<node name> -port *<port name> -mode network
    • If you removed a NIC I/O module and installed a storage I/O module, install and cable your NS224 shelves, as described in Hot-add workflow.
  13. Repeat these steps for controller B.
