Boot media replacement workflow for an ASA A70 or ASA A90 system using the automated boot recovery process
Get started with replacing the boot media in your ASA A70 and ASA A90 storage system by reviewing the replacement requirements, shutting down the controller, replacing the boot media, restoring the image on the boot media, and verifying the system functionality.
Review the requirements for boot media replacement.
Shut down the controller in your storage system when when you need to replace the boot media.
Remove the failed boot media from the System Management module and install the replacement boot media.
Restore the ONTAP image from the partner controller.
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit.
