Install and maintain
Overview of boot media recovery - ASA A70 and ASA A90
Contributors dougthomp netapp-jsnyder
Boot media recovery for your ASA A70 or ASA A90 storage system uses the boot image from the partner node and automatically runs the appropriate boot menu option to install the boot image on your replacement boot media.
When you encounter boot error messages similar to the one shown below, you need to replace the boot media and restore the ONTAP image from the partner node.
Can't find primary boot device u0a.0
Can't find backup boot device u0a.1
ACPI RSDP Found at 0x777fe014
Starting AUTOBOOT press Ctrl-C to abort...
Could not load fat://boot0/X86_64/freebsd/image1/kernel: Device not found
ERROR: Error booting OS on: 'boot0' file: fat://boot0/X86_64/Linux/image1/vmlinuz (boot0, fat)
ERROR: Error booting OS on: 'boot0' file: fat://boot0/X86_64/freebsd/image1/kernel (boot0, fat)
Autoboot of PRIMARY image failed. Device not found (-6)
LOADER-A>
