Install and maintain
Replace the real-time clock battery in an ASA A1K system
Contributors netapp-jsnyder dougthomp
Replace the real-time clock (RTC) battery, commonly known as a coin cell battery, in your ASA A1K system to ensure that services and applications relying on accurate time synchronization remain operational.
Before you begin
  • Understand that you can use this procedure with all versions of ONTAP supported by your system.
  • Make sure all other components in the system are functioning properly; if not, you must contact contact NetApp support.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Remove the controller module
You must remove the controller module from the enclosure when you replace the controller module or replace a component inside the controller module.
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
Steps
  1. Check the NVRAM status LED located in slot 4/5 of the system. There is also an NVRAM LED on the front panel of the controller module. Look for the NV icon:
    NVRAM attention and status LED location graphic
    Callout number 1
    NVRAM status LED
    Callout number 2
    NVRAM attention LED
    • If the NV LED is off, go to the next step.
    • If the NV LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact Technical Support for assistance.
  2. On the front of the unit, hook your fingers into the holes in the locking cams, squeeze the tabs on the cam levers, and gently, but firmly rotate both latches toward you at the same time.
    The controller module moves slightly out of the enclosure.
    Controller remove graphic
    Callout number 1
    Locking cam latches
  3. Slide the controller module out of the enclosure and place it on a flat, stable surface.
    Make sure that you support the bottom of the controller module as you slide it out of the enclosure.
Step 3: Replace the RTC battery
Remove failed RTC battery and install the replacement RTC battery.
Steps
  1. Open the controller air duct on the top of the controller.
    1. Insert your fingers in the recesses at the far ends of the air duct.
    2. Lift the air duct and rotate it upward as far as it will go.
  2. Locate the RTC battery under the air duct.
    Callout number 1
    RTC battery and housing
  3. Gently push the battery away from the holder, rotate it away from the holder, and then lift it out of the holder.
    Note Note the polarity of the battery as you remove it from the holder. The battery is marked with a plus sign and must be positioned in the holder correctly. A plus sign near the holder tells you how the battery should be positioned.
  4. Remove the replacement battery from the antistatic shipping bag.
  5. Note the polarity of the RTC battery, and then insert it into the holder by tilting the battery at an angle and pushing down.
  6. Visually inspect the battery to make sure that it is completely installed into the holder and that the polarity is correct.
Step 4: Reinstall the controller module
Reinstall the controller module and boot it.
Steps
  1. Ensure the air duct is completely closed by rotating it down as far as it will go.
    It must lie flush against the controller module sheet metal.
  2. Align the end of the controller module with the opening in the enclosure, and slide the controller module into the chassis with the levers rotated away from the front of the system.
  3. Once the controller module stops you from sliding it farther, rotate the cam handles inward until they latch back under the fans
    Note Do not use excessive force when sliding the controller module into the enclosure to avoid damaging the connectors.
    The controller module begins to boot as soon as it is fully seated in the enclosure.
  4. Return the impaired controller to normal operation by giving back its storage: storage failover giveback -ofnode impaired_node_name.
  5. If automatic giveback was disabled, reenable it: storage failover modify -node local -auto-giveback true.
  6. If AutoSupport is enabled, restore/unsuppress automatic case creation: system node autosupport invoke -node * -type all -message MAINT=END.
Step 5: Reset the time and date on the controller
Note After replacing the RTC battery, inserting controller and powering on first BIOS reset, you will see the following error messages: RTC date/time error. Reset date/time to default RTC power failure error These messages are excpected and you can continue with this procedure.
Steps
  1. Check the date and time on the healthy controller with the cluster date show command.
Note If your system stops at the boot menu, select the option for Reboot node and respond y when prompted, then boot to LOADER by pressing Ctrl-C
  1. At the LOADER prompt on the target controller, check the time and date with the cluster date show command.
  2. If necessary, modify the date with the set date mm/dd/yyyy command.
  3. If necessary, set the time, in GMT, using the set time hh:mm:ss command.
    1. Confirm the date and time on the target controller.
    2. At the LOADER prompt, enter bye to reinitialize the PCIe cards and other components and let the controller reboot.
Step 6: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
