Replace the Flash Cache module carrier or caching module in a FAS70 or FAS90 system
The NVMe SSD Flash Cache module carrier in your FAS70 or FAS90 system contains one or two Flash Cache modules (caching modules) with a single SSD Flash Cache drive integrated into each caching module.
The FAS70 supports 2TB caching modules and FAS90 supports 4TB caching modules. You cannot mix caching modules of different capacity in the Flash Cache module carrier.
You can perform either of the following procedures depending on what component you need to replace: the entire Flash Cache module carrier or a caching module.
The Flash Cache module carrier is located in slot 6 and houses up to two Flash Cache modules. You cannot hot-swap the Flash Cache module carrier
Verify that your storage system has the appropriate operating system for the replacement Flash Cache module carrier.
Confirm all other components are functioning properly. If they aren't, contact technical support.
Step 1: Shut down the impaired node
Shut down or take over the impaired controller using one of the following options.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a SAN system, you must have checked event messages (
cluster kernel-service show) for the impaired controller SCSI blade. Thecluster kernel-service showcommand (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback:
Enter the following command from the console of the healthy controller:
Enter
ywhen you see the prompt Do you want to disable auto-giveback?
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…
Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings you to the LOADER prompt.
You must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state:
metrocluster node show
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h -
Enter
Go to the next section.
ywhen prompted.System prompt or password prompt (enter system password)
Step 2: Replace the Flash Cache module carrier
Perform the following steps to replace the Flash Cache module carrier.
If you are not already grounded, properly ground yourself.
Locate the failed Flash Cache module carrier, in slot 6, by the lit amber Attention LED on the front of the Flash Cache module carrier.
Caching module slot numbers
Flash Cache module carrier cam handle
Flash Cache module carrier fault LED
Remove the failed Flash Cache module carrier:
Rotate the cable management tray down by pulling the buttons on both sides on the inside of the cable management tray and then rotate the tray down.
Pinch the blue tab at the bottom of the Flash Cache module carrier.
Rotate the tab away from the module.
Pull the Flash Cache module carrier out of the controller module and set it on an antistatic mat.
Move the caching modules to the replacement Flash Cache module carrier:
Pinch the Terra Cotta tab at the top of the caching module and rotate the cam handle away from the caching module.
Remove the module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the Flash Cache module carrier.
Install the caching module into the same slot in the replacement Flash Cache module carrier and rotate the cam handle to the closed position on the caching module to lock it in place.
Repeat these steps if there is a second caching module.
Install the replacement Flash Cache module carrier into the system:
Align the module with the edges of the enclosure slot opening.
Gently slide the module into the slot all the way into the enclosure, and then rotate the cam latch all the way up to lock the module in place.
Rotate the cable management tray up to the closed position.
Step 3: Reboot the controller
After you replace the Flash Cache module carrier, you must reboot the controller module.
From the LOADER prompt, reboot the node: bye
This reinitializes the I/O cards and other components and reboots the node. -
Return the node to normal operation: storage failover giveback -ofnode impaired_node_name
If automatic giveback was disabled, reenable it: storage failover modify -node local -auto-giveback true
Step 4: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
Replace the caching module
The Flash Cache modules (caching modules) are located in slot 6-1 or in slot 6-2 or in both slot 6-1 and slot 6-2.
You can hot-swap the individual caching modules with caching modules of the same capacity from the same vendor or from a different supported vendor.
Verify that the replacement caching module has the same capacity as the failed one, from the same vendor or from a different supported vendor.
The drives in the caching modules are not field replaceable units (FRU). You must replace the entire caching module.
Locate the failed caching module, in slot 6, by the lit amber Attention LED on the front of the caching module.
Prepare the caching module slot for replacement as follows:
Record the caching module capacity, part number, and serial number on the target node: system node run local sysconfig -av 6
In admin privilege level, prepare the target caching module slot for removal, responding
ywhen prompted whether to continue: system controller slot module remove -node node_name -slot slot_number The following command prepares slot 6-1 on node1 for removal, and displays a message that it is safe to remove:::> system controller slot module remove -node node1 -slot 6-1 Warning: SSD module in slot 6-1 of the node node1 will be powered off for removal. Do you want to continue? (y|n): _y_ The module has been successfully removed from service and powered off. It can now be safely removed.
Display the slot status with the
system controller slot module showcommand.The caching module slot status displays
powered-offin the screen output for the caching module that needs replacing.
See the Command man pages for your version of ONTAP for more details. -
Remove the caching module:
Caching module cam handle
Caching module fault LED
Press the terra cotta release button on the front of the caching module.
Rotate the cam handle as far as it will go.
Remove the caching module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the Flash Cache module carrier.
Be sure to support the caching module as you remove it from the Flash Cache module carrier.
Install the replacement caching module:
Align the edges of the caching module with the opening in the controller module.
Gently push the caching module into the bay until the cam handle engages.
Rotate the cam handle until it locks into place.
Bring the replacement caching module online by using the
system controller slot module insertcommand as follows:The following command prepares slot 6-1 on node1 for power-on, and displays a message that it is powered on:
::> system controller slot module insert -node node1 -slot 6-1 Warning: NVMe module in slot 6-1 of the node localhost will be powered on and initialized. Do you want to continue? (y|n): `y` The module has been successfully powered on, initialized and placed into service.
Verify the slot status using the
system controller slot module showcommand.Make sure that the command output reports the status as
powered-onand ready for operation. -
Verify that the replacement caching module is online and recognized, and then visually confirm that the amber attention LED is not lit:
sysconfig -av slot_numberIf you replace the caching module with a caching module from a different vendor, the new vendor name is displayed in the command output. -
