Review requirements for installing an AFF A70 or AFF A90 storage system
Review the equipment needed and the lifting precautions for your AFF A70 or AFF A90 storage system and storage shelves.
Equipment needed for install
To install your storage system, you need the following equipment and tools.
Access to a Web browser to configure your storage system
Electrostatic discharge (ESD) strap
Flashlight
Laptop or console with a USB/serial connection
Phillips #2 screwdriver
Lifting precautions
Storage systems and shelves are heavy. Exercise caution when lifting and moving these items.
Storage system weight
Take the necessary precautions when moving or lifting your storage system.
The storage system can weigh up to 151.68 lbs (68.8 kg). To lift the storage system, use four people or a hydraulic lift.
Shelf weight
Take the necessary precautions when moving or lifting your shelf.
An NS224 shelf can weigh up to 66.78 lbs (30.29 kg). To lift the shelf, use two people or a hydraulic lift. Keep all components in the shelf (both front and rear) to prevent unbalancing the shelf weight.
After you've reviewed the hardware requirements, you prepare to install your AFF A70 or AFF A90 storage system.
