AFF C30 and AFF C60 chassis replacement workflow
Get started with replacing the chassis of your AFF C30 or AFF C60 storage system by reviewing the replacement requirements, shutting down the controllers, replacing the chassis, and verifying system operations.
To replace the chassis, you must meet certain requirements.
Shut down the controllers so you can perform maintenance on the chassis.
Replacing the chassis includes moving the drives, any drive blanks, controllers (with the power supplies), and the bezel from the impaired chassis to the new chassis. It also includes swapping out the impaired chassis with a new chassis of the same model.
Verify the HA state of the chassis and return the failed part to NetApp.
