Install and maintain
Install two-post support rail kits for an AFF A700 or FAS9000 system
Contributors netapp-jsnyder netapp-lisa
There are two, two-post support rail kits that can be used with the FAS9000 and AFF A700 systems. One kit allows you to flush-mount your system in the two-post rack, and the other kit allows you to mid-mount your system in the two-post rack.
Install the two-post mid-mount rail kit
How to install the two post mid mount rail kit
Install the two-post flush-mount rail kit
How to install the two post flush mount rail kit
