Install and maintain
Replace the caching module - AFF A220
You must replace the caching module in the controller module when your system registers a single AutoSupport (ASUP) message that the module has gone offline; failure to do so results in performance degradation.
  • You must replace the failed component with a replacement FRU component you received from your provider.
Step 1: Shut down the impaired controller
To shut down the impaired controller, you must determine the status of the controller and, if necessary, take over the controller so that the healthy controller continues to serve data from the impaired controller storage.
About this task
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller.
You might want to erase the contents of your caching module before replacing it.
Steps
  1. Although data on the caching module is encrypted, you might want to erase any data from the impaired caching module and verify that the caching module has no data:
    1. Erase the data on the caching module: system controller flash-cache secure-erase run -node node name localhost -device-id device_number
      Note Run the system controller flash-cache show command if you don't know the Flash Cache device ID.
    2. Verify that the data has been erased from the caching module: system controller flash-cache secure-erase show
  2. If the impaired controller is part of an HA pair, disable automatic giveback from the console of the healthy controller: storage failover modify -node local -auto-giveback false
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt (enter system password)
    Take over or halt the impaired controller:
    • For an HA pair, take over the impaired controller from the healthy controller: storage failover takeover -ofnode impaired_node_name
      When the impaired controller shows Waiting for giveback…​, press Ctrl-C, and then respond y.
    • For a stand-alone system: system node halt impaired_node_name
  4. If the system has only one controller module in the chassis, turn off the power supplies, and then unplug the impaired controller's power cords from the power source.
Step 2: Remove controller module
To access components inside the controller, you must first remove the controller module from the system and then remove the cover on the controller module.
Steps
  1. If you are not already grounded, properly ground yourself.
  2. Loosen the hook and loop strap binding the cables to the cable management device, and then unplug the system cables and SFPs (if needed) from the controller module, keeping track of where the cables were connected.
    Leave the cables in the cable management device so that when you reinstall the cable management device, the cables are organized.
  3. Remove and set aside the cable management devices from the left and right sides of the controller module.
    Inserting or removing the cable management arm
  4. Squeeze the latch on the cam handle until it releases, open the cam handle fully to release the controller module from the midplane, and then, using two hands, pull the controller module out of the chassis.
    Opening the cam handle latch
  5. Turn the controller module over and place it on a flat, stable surface.
  6. Open the cover by sliding in the blue tabs to release the cover, and then swing the cover up and open.
    Opening or closing the controller module
Step 3: Replace a caching module
To replace a caching module referred to as the M.2 PCIe card on the label on your controller, locate the slot inside the controller and follow the specific sequence of steps.
Your storage system must meet certain criteria depending on your situation:
  • It must have the appropriate operating system for the caching module you are installing.
  • It must support the caching capacity.
  • All other components in the storage system must be functioning properly; if not, you must contact technical support.
Steps
  2. Locate the caching module at the rear of the controller module and remove it.
    1. Press the release tab.
    2. Remove the heatsink.
    Removing a caching module
  3. Gently pull the caching module straight out of the housing.
  4. Align the edges of the caching module with the socket in the housing, and then gently push it into the socket.
  5. Verify that the caching module is seated squarely and completely in the socket.
    If necessary, remove the caching module and reseat it into the socket.
  6. Reseat and push the heatsink down to engage the locking button on the caching module housing.
  7. Close the controller module cover, as needed.
Step 4: Reinstall the controller module
After you replace components in the controller module, reinstall it into the chassis.
Steps
  2. If you have not already done so, replace the cover on the controller module.
  3. Align the end of the controller module with the opening in the chassis, and then gently push the controller module halfway into the system.
    Note Do not completely insert the controller module in the chassis until instructed to do so.
  4. Recable the system, as needed.
    If you removed the media converters (QSFPs or SFPs), remember to reinstall them if you are using fiber optic cables.
  5. Complete the reinstallation of the controller module:
    If your system is in…​ Then perform these steps…​
    An HA pair
    The controller module begins to boot as soon as it is fully seated in the chassis.
    1. With the cam handle in the open position, firmly push the controller module in until it meets the midplane and is fully seated, and then close the cam handle to the locked position.
      Note Do not use excessive force when sliding the controller module into the chassis to avoid damaging the connectors.
      The controller begins to boot as soon as it is seated in the chassis.
    2. If you have not already done so, reinstall the cable management device.
    3. Bind the cables to the cable management device with the hook and loop strap.
    A stand-alone configuration
    4. Reconnect the power cables to the power supplies and to the power sources, and then turn on the power to start the boot process.
Step 5: Switch back aggregates in a two-node MetroCluster configuration
After you have completed the FRU replacement in a two-node MetroCluster configuration, you can perform the MetroCluster switchback operation. This returns the configuration to its normal operating state, with the sync-source storage virtual machines (SVMs) on the formerly impaired site now active and serving data from the local disk pools.
This task only applies to two-node MetroCluster configurations.
Steps
  1. Verify that all nodes are in the enabled state: metrocluster node show
    cluster_B::>  metrocluster node show
    DR                           Configuration  DR
    Group Cluster Node           State          Mirroring Mode
    1     cluster_A
                  controller_A_1 configured     enabled   heal roots completed
          cluster_B
                  controller_B_1 configured     enabled   waiting for switchback recovery
    2 entries were displayed.
  2. Verify that resynchronization is complete on all SVMs: metrocluster vserver show
  3. Verify that any automatic LIF migrations being performed by the healing operations were completed successfully: metrocluster check lif show
  4. Perform the switchback by using the metrocluster switchback command from any node in the surviving cluster.
  5. Verify that the switchback operation has completed: metrocluster show
    The switchback operation is still running when a cluster is in the waiting-for-switchback state:
    cluster_B::> metrocluster show
    Cluster              Configuration State    Mode
     Local: cluster_B configured       	switchover
    Remote: cluster_A configured       	waiting-for-switchback
    The switchback operation is complete when the clusters are in the normal state.:
     Local: cluster_B configured      		normal
    Remote: cluster_A configured      		normal
    If a switchback is taking a long time to finish, you can check on the status of in-progress baselines by using the metrocluster config-replication resync-status show command.
  6. Reestablish any SnapMirror or SnapVault configurations.
Step 6: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
